Double timing sprocket
Old Feb 13, 2013 | 03:04 PM
Dam20735's Avatar
Default Double timing sprocket
I'm trying to figure out what timing mark do I use it's a zero on the outer ring an then it's another one on the inner which is the timing mark
Old Feb 13, 2013 | 03:06 PM
PacerSS's Avatar
Outer and inner make no sense to me. I know there's 3 sprockets, cam, crank, and balancer. Which ones are you talking about?
Old Feb 13, 2013 | 03:40 PM
Dam20735's Avatar
The one that goes on the crank with the timing chain
Old Feb 13, 2013 | 03:51 PM
PacerSS's Avatar
There's two 0 marks on both, you want them to point at each other when they come around. They are both keyed so they will only go on one way. Unless you got a dual rollmaster setup like mine.
Anyway the cam is a lot easier to turn without lifters and rockers pushing it down, so adjust it there until it lines up with the crank.
Like so:
Old Feb 13, 2013 | 03:53 PM
PacerSS's Avatar
Oh and the second mark you are talking about on the very lip of it is for the oil pump gear. If you look at the timing cover there's a gear with a similar mark.
Old Feb 13, 2013 | 04:19 PM
Dam20735's Avatar
It doesn't have a mark it has number 6 4 2 0 2 4 6 on the inner lip an the same on the outer lip but they are different on the outer lip
Old Feb 13, 2013 | 05:59 PM
PacerSS's Avatar
All that matters really is the timing diagram above. The oil pump gear will only fit on the right way.
Old Feb 13, 2013 | 06:09 PM
03SSLE's Avatar
The 6 4 2 0 2 4 6 on the sprockets is so that you can advance/retard the cam timing. Unless you are well versed on engine building and the engine was assembled from the start with the idea of running advanced/retarded cam timing it is something I suggest you do not attempt. Align the sprockets so that the '0' on each point to one another (like in the diagram Pacer provided) and you'll be all set.
Dam20735
Jun 3, 2013 07:45 AM
Dam20735
May 23, 2013 04:09 PM
Dam20735
May 19, 2013 05:32 PM
Dam20735
Sep 19, 2012 05:36 AM
MonteGrrl48174
Nov 2, 2006 09:38 PM
