Display Mat For Your Monte
Old May 23, 2009 | 07:32 PM
mavrickf1613's Avatar
Monte Of The Month -- January 2009
Default Display Mat For Your Monte
I found the rubber matts that go underneath your Monte Carlo in your garage or for a car show, These matts are available at LOWES
Check out the link
http://www.reflexmouldingsusa.com/diamondplate.html
This is affordable and is in the flooring department in your local LOWES
Old May 23, 2009 | 08:30 PM
The Popcorn King's Avatar
Thats a kewl idea for a display. Just make them checkerboard and you got yourself something nice.
Old May 23, 2009 | 10:05 PM
mavrick, i just tried sending a message but it said you have to many messages, so here goes this one, thanks for your response on cardomain about the cai you have installled, later man
mavrick, thanks man, i'm just looking for ideas on improving my car and i saw your sweet cai from cardomain, i was just wondering if it was very hard to install, if i would get one, should i get it professionally installled? let me know, also your car is pretty sweet and i saw a couple of contacts/friends and the one guy has a sick looking monte carlo with a cool dash and other interior mods, thanks, later
chris
Old May 24, 2009 | 02:40 AM
my inbox is full sorry to all for my messages not getting through, I will empty it
Its easy to install the COLD AIR INTAKE, it comes with instructions and if you need any help when you install it you can post here and we will help you with any questions to install it and if you really need to I can give you my phone number in message so when your installing it I can try to guide you over the phone.
You take the old air box out by using a srew driver and a flat head, You take the air box lid off and then take the air filter out then take the pcm out and unscrew the box from the bottom out and take the mass air flow sensor out and air hose out.
Now you place the new cold air intake box in and screw it together like the instructions would say there is a plate first then the pcm sits on top and screws in over the plate then the box sits above this and srews into place, then put the air filter in the box and and then connect the mass air flow sensor to the air filter and then the air hose to the mass air flow sensor and then the hose to the throttle body on the engine.
Don't forget to take off the brace over the intake in the first place,
you should ask a friend to help you, I had my uncle help me just so I had an extra set of hands to hold two pieces together so I could screw things in place. It takes like an hour to do, the instructions are clear and its something you can install yourself, if somebody were to install it for you I wouldn't pay more than $50 or $100 at the most to have it done, save that money and do it yourself, because when you need to clean your air filter with the recharge kit K and N makes then you can do this yourself and won't have to throw a $50 dollar air filter away, Cleaning the air filter and putting it back on is easy after you done it once,
cali2000ss
Jun 21, 2015 01:26 PM
Teacher
Aug 26, 2009 07:11 AM
mavrickf1613
Dec 8, 2008 12:34 AM
Kelt
Oct 27, 2007 07:57 PM
BeachBumMike
Jul 2, 2007 10:42 AM
