check engine light
Old Aug 7, 2010 | 01:13 AM
z34_98blue's Avatar
Default check engine light
my check engine light has been coming on and i have checked the code and each time its saying an evap problem and it also says that the car is going 0mph at around 9000rpm. i don't know what is going on with this but its about ever week that i have to clear the code. does anyone know what this could be and how i can fix it?
Old Aug 7, 2010 | 05:57 AM
RocknSS04's Avatar
It'd help if you told us what the codes were.
Evap , just guessing, is the cannister at the tank os old and needs to be replaced. I replaced mine a few months back.
Old Aug 8, 2010 | 01:53 AM
z34_98blue's Avatar
it will be about a week before i can get the code again haha cause that is when it will be back on.
Old Aug 8, 2010 | 02:21 AM
That doesn't make any sense- why are you clearing the code unless you think you've fixed the problem? The car will shut the light off when it passes the automatic test; but as long as it fails the test each time, you'll just keep getting the light.
Like Rockn said, we need more information- specifically the code #. There are a lot of possible codes, and even a few different ones that deal with the evap system. It could be anything from the solenoid purge valve being stuck, to the gas cap not put on all the way, to a vacuum leak somewhere in the system- but without the code, we can't really be of much help.
hotrodharley
Nov 15, 2013 11:37 AM
J_Bru_Ha_SS
Jul 30, 2007 09:08 PM
BeachBumMike
Sep 21, 2006 10:48 PM
malletboy
May 28, 2006 06:07 PM
rich131
Dec 16, 2005 02:07 AM
