Center Council
Old Jun 4, 2011 | 11:34 PM
Default Center Council
Hey, has anyone here removed the center counsel? It's coated with some weird black rubberized thing and I want to redo it all, I can get it all the way off until it gets to where it's underneath the dash, then it seems to have some weird push screws or something. I'm wondering if anyone has done this yet and has a solution or an easy way to get it completely off, thanks!
Old Jun 5, 2011 | 12:07 AM
03Monte's Avatar
have you removed the screw under the removable rubber pad?
the center console separates into two pieces you will need to move your shifter down to get it off, once the top is off there are two big screws in the center remove them and the bottom half should lift out
Old Jun 5, 2011 | 12:09 AM
03Monte's Avatar
you can see the screw hole in this photo.
Old Jun 5, 2011 | 11:23 AM
nemesis's Avatar
2009 Monte Of The Year
* fixed* you spelled CONSOLE wrong...come on college boy get with the program! lol. been awhile since i took the console out, sound about right what the other guy said^^^. if i remember i think there might be 1 or 2 screws inside the center console arm rest lid. like he said the shifter need to shift all the way back bcuz you need to pull the console back toward you out cuz the lower bottom dash is in the way. don't forget to unplug the traction and heated seated harness if you have one first before pulling out.
Old Jun 5, 2011 | 09:24 PM
it was late lol i couldn't remember how to spell it haha, so there's just that one screw under the rubber mat part? that's all i can see in that picture. you pull the black part off first and then the gray part right?
Old Jun 5, 2011 | 10:14 PM
Enzo354's Avatar
STILL SLOW
Thats the only screw. I always pull up towards the back and lift towards the front, works the easiest imo.
Old Jun 5, 2011 | 11:05 PM
thanks, ill do it tomorrow then i think
Bowtie_Brother
Aug 9, 2006 06:29 PM
Moffer
Jul 17, 2005 12:28 AM
big green dog
May 5, 2005 05:17 PM
