blew the motor
Old Oct 4, 2008 | 03:32 PM
loudNproudSS's Avatar
Default blew the motor
today when i was going to get my new power steering belt from NAPA and on the way home i lost oil pressure and it stalled. i started it back up and limped into a parking lot. it had a little bit of oil pressure and wasnt makin noise so i drove home easy (2 miles) got in the driveway and it stalled again, started it back up and now its knocking. its not really a knock, but its got a nice loud rattling sound in the bottom end. RIP 305, time for a 350.
Old Oct 4, 2008 | 03:42 PM
Default RE: blew the motor
Hi Tony,
Been there, done that : (
and it SUCKS 4 $ure : (
[X(][X(][X(][X(][X(][X(][X(][X(][X(]
[X(][X(][X(]R.I.P. 5.0 [X(][X(][X(]
Just 2 many high Rev`s can Smoke a Engine : (
I hope that you can find a good 350 C.I. 2 replace $
Will you get a new Crate, or look 4 a good used one ?
Are you going to tear the 5.0 down to see what is broken ?
Does it sound like a Rod ?
Tony, wish you better luck, and hopefully your future cost
will be rewarded with a SuperSuperSuper Fast SS
Good Luck from `Space & the BeachBums
Keep us updated `ok
Old Oct 4, 2008 | 06:25 PM
i think its the rod bearings. i cant afford a crate, so used will be the way to go. hopefully i can afford to get another vehicle because it was my daily driver, so unfortunately i might have to let the car go.
Old Oct 4, 2008 | 06:28 PM
Cowboy6622's Avatar
o noes!! well stick with us here on hte MCF, you'll still have a home here as a former Monte owner just like 'Space
Old Oct 4, 2008 | 06:51 PM
LOL@ o noes!!!
ill stick around, but hopefully ill be asking for help with the motor swap, rather than whining about how much i miss the monte lol.
Old Oct 4, 2008 | 06:57 PM
Cowboy6622's Avatar
haha, NY is a LOOOoonnng way to help pull a motor, LoL
Old Oct 4, 2008 | 07:42 PM
i meant advice lol
Old Oct 4, 2008 | 08:09 PM
inssanity21's Avatar
is it possible to put a ls1 in it? that would be relatively cheap only cause they are in alot of silverados and suburbans tahoes, firebirds, camaros and so on. if it can you could pick one up for cheap and posiible put a blower on it!!! could be sweeet!
yeah i have soem crazy ideas you could also pull a 5.3 and bore it to 5.7.. im always thinking...
it would be a sight to see if its possible
Old Oct 5, 2008 | 04:18 AM
ORIGINAL: loudNproudSS
Hi `Tony,
I really hope you can find a way to keep your Monte SS.
I would check your local salvage yards, and places like
Craig`s List in your area. Also, do Google Searches.
Below is one example I found.
Wish you better luck 4-Sure.
Oh, I`m still whin`ing "I miss my Monte"
[align=center]
350 ci (5.7) L 98 small block chevy
stock rebuilt, 9.5 to 1 compression ratio
[/align][/align][align=center]
[/align][/align][/align][/align][/align]$1,250.00
I have a completely rebuilt SBC 350 long block out of a 87 Camaro with fuel injection. It is all stock, bore, stroke, cam, etc; but has been rebuilt with a replacement crankshaft kit with .010 main and rod journals and Seal Power bearings. Also replaced were the piston rings (PC moly), timing gears and chain, Mellings HV oil pump with new screen and drive rod, all high quality parts, all new Felpro gaskets and seals. The cylinder heads were pressure tested, checked surface flatness, valves and guides redone. The engine has the oil pan, front TC cover, and valve covers on it with the harmonic balancer and flexplate attached. This engine had very low miles on it before the rebuild and will make a nice replacement for someone. For more info or pics email or call. [/align]Seller Phone Number: 352-596-2448
Seller Phone Number2: 352-238-7814
Race Ads | For Sale: 350 ci (5.7) L 98 small block chevy
350 ci (5.7) L 98 small block chevy,I have a completely rebuilt SBC 350 long ... The engine has the oil pan, front TC cover, and valve covers on it with the ...
www.racingjunk.com/post/1329551/350-ci-5.7-L-98-... - 27k - Similar pages
http://www.racingjunk.com/post/13295...ock-chevy.html
02montecSS
17
Oct 14, 2010 01:17 AM
monte07
14
Jul 16, 2010 04:02 PM
phoenixdude24
Apr 22, 2010 03:10 PM
ltrain925
Dec 22, 2009 11:39 AM
97z34
Jan 20, 2007 01:30 PM
