Big Problem With My Monte!
So I was trying to leave the house and when I got down to the car and put the key in the ignition my key wont turn at all, i can pull the key out no problem but all i get is the stupid damn chime telling me "hey dumbass your key is in the ignition" i tried rocking the steering wheel, the car is in park. What am I suppose to do?!?
Jiggle it up and down! sounds weird and may not be the issue but the key we got with our intrigue(also a w-body) you had to jiggle the key up and down to get all the tumblers to aline correctly becuase the key was worn down from repeated use,
As odd is it sounds, make sure the key cylinder is turned ALL the WAY to OFF. I've had some vehicles that the tumblers wore enough you could get the key close to off and pull it out (and one of those was a truck, if you pulled the key out before off, you could start the truck without the key).
Well if its going to get fixed I want it done right, I don't want to be using some aftermarket ignition cylinder and some off brand keys. Thats just how I've always been, if I replace or fix something I want it done right.
Sorry to read about your problem
Check out the below links from our Forum.
Good Luck 4-Sure...
key won't turn ignition cylinder - Monte Carlo Forum - Monte Carlo ...
5 posts - 3 authors - Last post: Dec 10, 2009
Turn OFF the ignition and wait 5 seconds. Turn key to START, ... I needed to get it fixed right away so the local gm dealer said $300 plus ...
montecarloforum.com/...8/key-wont-turn-ignition-cylinder-17467/ - Cached key won't turn in ignitin cylinder - Monte Carlo Forum - Monte ... - Mar 31, 2011
Key problem - Jan 31, 2011
I'm from Southern Il. - Jul 8, 2010
More results from montecarloforum.com »
