Best way to get stickers off
Old 01-30-2013 | 11:01 PM
iMuf's Avatar
Default Best way to get stickers off
I wasn't sure what section to put this in so I figured I would put it here. Anyway, I recently just got my 06 Monte Carlo SS and on the back where the SS badge is I have a sticker from the place I got it from. What is the best way to get this off without hurting the paint?
Old 01-30-2013 | 11:19 PM
tps221's Avatar
WD-40 and let it sit then putty knife and it will practically fall off
Old 01-30-2013 | 11:31 PM
a putty knife..... not on my car.......
Old 01-31-2013 | 02:27 AM
If it hasnt been on there long it should peel right off
Old 01-31-2013 | 02:33 AM
Dstevens's Avatar
I used a razor and water. Just started it and got the remains with the razor. no damage but you have to have a really steady hand.
Old 01-31-2013 | 04:27 AM
I peeled the lettering off then used a heat gun and rubbed the rest off
Old 01-31-2013 | 07:41 AM
I do the heat and peel technique to remove everything. For the glue that is left over, I like using goof-off rubbing. Takes a good amount of elbow grease
Then you need to compound, polish, and wax that area really well
Old 01-31-2013 | 08:14 AM
iMuf's Avatar
Thanks guys I appreciate it.
Old 01-31-2013 | 09:33 AM
Never use WD-40 on your paint!
You wont have any paint left on your car!
Removeing a sticker thats on the paint is never good! I'd X2 with Mike (chibi) as far as removeing stickers off the paint!
Old 01-31-2013 | 09:53 AM
Enzo354's Avatar
STILL SLOW
This^^^
I work at a body shop that does buses/ campers. We use the heat gun for everything, and if you have seen the size of some of the stuff we remove, you would trust me.
Quick Reply: Best way to get stickers off
