Best Bang for my buck?
Looking at some cheap parts to pick up some improvements to the monte but cant decide so I turn to you guys/gals and your knowledge and experience.
Here is what I already have:
K&N Intake
Thrush Turbo Mufflers on stock pipes
180* Tstat - needs to be installed
ZZP Stage 1 Voltage Booster
I'm not looking to spend a lot. $200 at most on some parts but don't know what will give me the most value. This is my daily driver so I'm keeping it N/A for now.
Please Help!
K&N Intake
Please Help!
are you just looking for parts i take it?
how about some headers if you can find them cheap? or you can always just remove the ubend in the exhaust.
also how about a bigger throttle body, those are right around the $200 range on sale right now i think at WOT, but you would also need for make the inlet on your intake manifold larger to match that port.
according to 3800performance.com they carry LSX grill for buick regal and impala only not monte carlo. i don't think neither grill will work on the monte.
http://www.3800performance.com/Merch...oduct_Count=15
You can have the U-bend deleted for about 60-80 $ from a muffler shop. This is a performance upgrade, not a cosmetic one, and it will allow your car to breathe and run better unleashing a few ponies in the process.
I honestly am not a big believer in the U-Bend delete by itself. Despite it's ugly appearance, it pretty much moves the same volume of air as the rest of the pipes (perhaps a SMALL difference). But, getting a full ZZP downpipe, which includes high flow cat and u-bend delete, a great start.
I would also say, if you can luck out like I did, get a set of L67 coils for $15-$20, those too work well (and cheap, $30 is the most I'd go for a good set of L67 coils as the change is minimal).
If you get the DP, a PLOG is probably a must (I finally have a PLOG to install on my Monte next spring).
NYGiantsfan
Aug 28, 2013 02:13 AM
