Argh!
I'd take it to the dealer and play the "man, this has happened to everyone I know who owns an 06-07 monte" card and see what they will do for you. I had mine repaired under warranty but the dealer new there is an issue. If I had to, I probably could have talked them down on repair price or gotten them to just charge for the part.
Thanks, I'll keep that in mind tomorrow when I start calling around.
Update:
Took the Monte to the dealer today after dumping in some fluid to keep the pump from drying out. Charged me for an hour of labor plus parts, total came to $138 and it was a line that had blown. I told them that I had heard of this being rather common but he said it wasn't, then I told him it normally happens with less miles, he asked how many I had and after telling him that I've got over 60k he said to bring it by for a look. First time I've ever had a dealer wash my car. With temps under 20 and winds over 30 plus wet snow earlier and icy snow later I didn't even notice until I got home.
Good experience with the local dealer overall. Called, waited an hour for a buddy to follow me for a ride, went to class, got called halfway through class saying it was done.
Well with 60K+ miles on my car something finally went out, lost my power steering and once I got home I can see and smell the fluid running out the bottom somewhere. Being in college I don't have a jack here so I haven't been able to see what exactly went out but whatever it is I'm not happy about it.
I'll update this once I see what's really broke...
Update:
Well I went and got a jack and looked around, whatever it is I can't see it because the transmission is in the way from underneath and everything else is in the way from above. I guess the next step is to see if any shops around here will tow it in and look at it.
Update:
listennnn im going to save you a lottttt of money same thing happen to me. and after spending 400 dollars later it turned out to be a 12 dollar job... its the reverse turn line.. dont let the mechanics tell you anything different. its not the pump the resvoir.. its the return line.. they will say it has no pressure on it blah blah but what happens is the way the montes are its sorta wears a small hole into it.. so yeahh that should help... ITS THE RETURN LINE!!!! chekc that out first.
