Argh!
Old Mar 28, 2009 | 04:54 PM
God_Bot's Avatar
Default Argh!
Well with 60K+ miles on my car something finally went out, lost my power steering and once I got home I can see and smell the fluid running out the bottom somewhere. Being in college I don't have a jack here so I haven't been able to see what exactly went out but whatever it is I'm not happy about it.
I'll update this once I see what's really broke...
Update:
Well I went and got a jack and looked around, whatever it is I can't see it because the transmission is in the way from underneath and everything else is in the way from above. I guess the next step is to see if any shops around here will tow it in and look at it.
Old Mar 28, 2009 | 05:53 PM
The secret is to run the car in reverse for a few thousand miles every now and then - just so it never hits 60,000. Nothing will break then.
[drum roll][crash]
I couldn't help myself. Sorry about your misfortune. I couldn't think of anyway to really help you out. I still think your better off having not purchased a VW
Old Mar 28, 2009 | 06:10 PM
God_Bot's Avatar
Lol, my roommate thinks I broke it on purpose so that I wouldn't have to drive to parties anymore...
Anyone have any ideas how much it usually runs to have hoses replaced? I don't think it's the pump 'cause I never had anything wrong, just lost steering and fluid at once.
Old Mar 28, 2009 | 06:46 PM
I was thinking the pump. But that's just a guess on my part. Hopefully what ever the problem is, it won't cost you too much.
Or you could forget about the power steering and build up some arm muscles like Ah-nold, the Gov-inator.
By the way Brent, didn't they try that in "Ferris Bueller's Day Off"?
Anyone? Anyone? Bueller?
Old Mar 28, 2009 | 11:01 PM
God_Bot's Avatar
It could be the pump, but it's not leaking from the pump. Either way I've got to wait 'till Monday to even call anyone to see how much it'll cost to have them look at it.
Old Mar 29, 2009 | 01:38 AM
Cully77's Avatar
Monte Of The Month -- May 2011
driving without PS can certainly be interesting haha, hope it doesnt cost too much on the repair
Old Mar 29, 2009 | 04:07 AM
Arrow P>S>Leaks/Broke : (
Hi Garrett,
Sorry 2 read about your prob's
Below is from a SpaceSearch:
Hope it gives you some idea's/solution
Good Luck
<LI about="r10">2007 Chevrolet Monte Carlo Technical Service Bulletin (TSB) Provides Information about 2007 Chevrolet Monte Carlo Recall, Technical Service ... Coolant leaking from engine (replace coolant crossover pipe gaskets). .... Information on 3.5l, 3.9l, and 5.3l e85 fuel compatible vehicles, with alcohol ... Steering. Summary: Power steering moan or groan noise while driving. ...
www.aboutautomobile.com/TSB/2007/Chevrolet/Monte... - 43k - Similar pages
http://www.aboutautomobile.com/TSB/2...et/Monte+Carlo
<LI about="r11">2007 CHEVROLET SILVERADO 1500 Technical Service Bu... Power steering pump leak/ incorrect mounting bolt. .... Information on 3.5l, 3.9 l, and 5.3l e85 fuel compatible vehicles, with alcohol content, ... This includes 1998-2006 chevrolet and GMC full and mid size trucks. Updated. ... Oil seepage from turbo air charge cooler hoses or hose blowing off during acceleration. ...
www.aboutautomobile.com/tsb/2007/CHEVROLE... - 69k - Similar pages
[ More results from www.aboutautomobile.com ]
http://www.aboutautomobile.com/tsb/2...SILVERADO+1500
<LI about="r12">Car maintenance, car safety reports at Edmunds COOLANT LEAKING FROM ENGINE (REPLACE COOLANT CROSSOVER PIPE GASKETS). .... Bulletin Number: 060941006. Bulletin Date: NOV 2006 ... INFORMATION ON 3.5L, 3.9 L, AND 5.3L E85 FUEL COMPATIBLE VEHICLES, WITH ALCOHOL ... Vehicle: 2007 Chevrolet Monte Carlo. Summary: POWER STEERING MOAN OR GROAN NOISE WHILE DRIVING . ...
https://www.edmunds.com/maintenance/recalltsb.do... - 104k - Similar pages
https://www.edmunds.com/maintenance/...+8cyl+4A)&zip=
<LI about="r13">2006 Chevrolet Silverado TSBs -- [ CarComplaints.com ] 2006 Chevrolet Silverado TSBs (Technical Service Bulletins) ... 2006 Chevrolet Malibu, 2006 Chevrolet Monte Carlo, 2006 Chevrolet Novo Vectra, 2006 Chevrolet ... TSB #4087 -- POWER STEERING PUMP LEAK/ INCORRECT MOUNTING BOLT. .... TSB # 060604010 -- INFORMATION ON 3.5L, 3.9L, AND 5.3L E85 FUEL COMPATIBLE VEHICLES, ...
www.carcomplaints.com/Chevrolet/Silverado/2006/t... - 46k - Similar pages
http://www.carcomplaints.com/Chevrol...006/tsbs.shtml
<LI about="r14">Chevy Impala Steering Rack - A1 Cardone, Maval - 2005, 2004,... Radiator Hose · Radiator Support .... Moog Steering Rack Boot Kit 2000-2006 Chevrolet Impala ... all of which work to prevent leaking, extend unit life, ... Fits: Power Steering, Exc. w/Sport Suspension FE3, GM Codes are on the "Service ... 2006-2006: LS; 6Cyl 3.9L GAS, FI, VIN "1";. 2006-2006: LT; 6Cyl 3.9L GAS, ...
www.car-stuff.com/mmparts/chevy-impala/steering_... - 161k - Similar pages
http://www.car-stuff.com/mmparts/che...ring_rack.html
<LI about="r15">iATN Member Auto Repair Tech Exchange for March 20, 2009 ... this vehicle was towed in and the lower raid hose connection was blown off we reinstalled it ... 2001 Dodge Grand Caravan 3.3L power steering van came in with no power steering and a noisy pump. .... After a multitude of testing; including a good leak down test, .... 2006 Chevrolet Monte Carlo 3.9L traction con ...
www.iatn.net/techmail/summaries/2009/03/20/ - 81k - Similar pages
http://www.iatn.net/techmail/summaries/2009/03/20/
<LI about="r16">iATN Member GM Auto Repair Tech Exchange for March... Mar 17, 2009 ... Need to replace a leaking seal. Alldata says to use a hammer and brass punch but I can't get it to move. Is there another method or is alldata ... 2006 Chevrolet Silverado 6.6L Hesitation, MIL Lamp on ... 2007 Chevrolet Monte Carlo 3.5L Cruise/Horn .... 2007 Chevrolet Impala 3.9L power steering pump ...
www.iatn.net/techmail/summaries/2009/03/1... - 38k - Similar pages
[ More results from www.iatn.net ]
http://www.iatn.net/techmail/summari.../03/17/gm.html
<LI about="r17">2006 Chevrolet Impala Comments - Carsurvey.org The 3.9L V6 had so much power, I had to pop the hood and see if it was a V8! .... and the rubber hose that connects the power steering line sprung a leak ...
www.carsurvey.org/reviews/chevrolet/impala/r8892... - 35k - Similar pages
Old Mar 29, 2009 | 04:28 AM
custom95's Avatar
it's a line, it's a very common failure on our cars. mine went this winter at around 38k. most people have it happen a lot sooner than you did. shop will probably charge a few hundred bucks. good news is the dealer will most likely have the part in stock because it's so common.
Old Mar 29, 2009 | 12:21 PM
God_Bot's Avatar
So would you recommend going to the dealer or going elsewhere? I know when my battery went out last year they wanted $50 just to check it. I said screw that and had a free test done at Advanced Auto and they fixed me up with a new battery.
Old Mar 29, 2009 | 01:06 PM
custom95's Avatar
I'd take it to the dealer and play the "man, this has happened to everyone I know who owns an 06-07 monte" card and see what they will do for you. I had mine repaired under warranty but the dealer new there is an issue. If I had to, I probably could have talked them down on repair price or gotten them to just charge for the part.
