6th Gen ('00-'05): anti locking and trax control
Old 07-01-2014 | 07:50 PM
lonerider's Avatar
Default anti locking and trax control
do es anyone know how to turn off the anti locking and trac control system ..i just had both bearings replaced...and the darn thing is still comimg on ..ie i know i have a short...but would like to disable the this for now...thanks..03 ss limited edition
Old 07-02-2014 | 12:21 PM
Johnlh97's Avatar
Well, I don't know the *proper* way to do it, but the previous owner just cut all the wires for ABS and Trac Control. As he had replaced both front hubs.
The car would begin to apply the breaks, as if it were losing traction as he would turn to get onto the highway, which almost caused him to get into many wrecks. he got sick of it, and just chopped the wires.
BUT, unless there is a proper way to do this, I don't recommend it at all!
Old 07-02-2014 | 08:22 PM
ohara's Avatar
Did you just replace the front wheel bearings? odds are you need to change one of the rear bearings, they have the abs wheel speed sensors as well.
If you know someone that has access to a obd II reader get the codes read and you will know which bearing needs to be replaced.
lonerider
06-04-2014 08:43 PM
BeachBumMike
05-04-2014 12:51 PM
chevyguy114
10-18-2012 11:07 PM
moonlitmagik
10-12-2009 03:56 PM
