Almost stranded :(
Old Mar 20, 2014 | 10:00 AM
steveinri's Avatar
Default Almost stranded - Switch changed :)
This morning (as usual) the Monte ran great, put on 25 miles to an appointment. After about 20 minutes returned to the car, go to start and "nothing" in the start position. It was not like a dead or weak battery but everything just turned off and no starter, more like a bad neutral safety switch. It would recycle if I turned the key off then ACC and ON would have power. After 15 minutes I called AAA and texted work that I'd be late. Gave it one last shot and it fired right up. Cancelled AAA and re-texted work and went straight home to switch cars.
I have been seeing a few issues indication that the ignition switch is bad like the CRUISE light flashing, the OHD not displaying and the SECURITY warning on the info center display. I wanted to wait for warmer weather but it looks like I will be swapping out the switch ASAP.
Old Mar 20, 2014 | 11:36 AM
are you also getting acheck engine light?
Old Mar 20, 2014 | 06:11 PM
steveinri's Avatar
No CEL today. Last one was quite a while ago for the AIR pump (P0410).I ordered a Dorman switch from Amazon. It will be here Saturday or Monday.
Old Mar 20, 2014 | 08:30 PM
solaris_vii's Avatar
loose battery cable? ive had that sort of thing happen in many cars
Old Mar 21, 2014 | 04:10 PM
steveinri's Avatar
It almost presents like a loose cable but its not. My rarely used 67 Chevelle would do the bad cable connection dance. Once it sparked everything would be dead then I'd have to twist the connection a bit more and try again.
I'll see what happens after the new switch.
Old Mar 22, 2014 | 06:58 PM
steveinri's Avatar
Changed the switch today. Easy job. Hopefully no more weird issues.
brockkrak
Nov 8, 2011 07:53 PM
Mar 24, 2010 11:24 AM
dustybird3
Mar 7, 2008 02:25 PM
bfurches
Feb 4, 2008 12:18 PM
01pacecar
Jul 23, 2007 07:38 PM
