Air conditioning disconnecting?=More Power
Old 07-08-2006 | 11:22 PM
zipsayain's Avatar
Default Air conditioning disconnecting?=More Power
Air conditioning disconnecting?=More Power Yes or No
If so how much HP?
Old 07-09-2006 | 12:32 PM
NYCRISS's Avatar
Default RE: Air conditioning disconnecting?=More Power
Well... yes. Any time you reduce the strain on a motor, you will gain power but there is more too it than that. Its not just a matter of pulling the plug on the compressor. You must bypass it IE re-rout the belt so that it is no longer being turned. On older cars this was simple but on newer cars with a serpentine belt set-up, it is a bit more of a challenge.
Old 07-09-2006 | 05:53 PM
benhillzone3's Avatar
it is not worth the trouble believe me i have tri dlol
Old 07-12-2006 | 12:19 AM
85_SS's Avatar
The "extra load" of the A/C pulley isn't worh worrying about it. The only time it sucks any noticeable amount of power is when you have the A/C running. Otherwise it is a free wheeling pulley with nearly no drag - don't worry about it
bcarson
08-23-2007 08:35 PM
bzapp
05-07-2007 04:29 PM
zipsayain
04-23-2006 12:34 AM
05montecarloLT
04-18-2006 06:12 PM
hersheybun88
10-11-2005 11:35 AM
Quick Reply: Air conditioning disconnecting?=More Power
