aftermarket tach
Old Oct 5, 2009 | 05:44 AM
itz2qk4u's Avatar
Arrow aftermarket tach
Hey all I'm new to montes..especially ones that have had the old
305G motor replaced, mine has a vortec 350/300hp, th350C
373 posi.
I put in a Autometer tach and now have an issue of both tachs working!! The stock tach reads considerably higher rpm , while the Autometer reads concerably lower rpm ( by about a 600-1000 rpms)
I should mention the factory ECM has been removed by the previous owner, car is an 84 SS.
There is also a silver box in the glove compartment that has settings from lean to rich in 5 increments, try as I might I cannot locate where these wires go, although there is no change in fuel if switched between selected increments.
Any help on the tach issue would be appreciated
thanks
Old Oct 5, 2009 | 05:56 AM
sideways's Avatar
Ya that is pretty common, go by the Autometer. The factory tachs aren't the most reliable.
Is the vortec motor Fuel injected or N/A?
Old Oct 5, 2009 | 04:30 PM
itz2qk4u's Avatar
Exclamation aftermarket tach
the engine is carbed...I need to know how to unhook the factory tach so
the new autometer tach reads correctly...thanks
Old Oct 5, 2009 | 05:00 PM
Budsjlm's Avatar
the autometer is more than likly accurate stock tacks ar not always verry acurate...and the box in the glove box sounds more like a advance and retard box for timing...since it's carbed i don't see
Old Oct 5, 2009 | 05:02 PM
Budsjlm's Avatar
how it coukd rich/lean by a dial cuz with mosr carbs that with jets and idler screws
Old Oct 5, 2009 | 05:28 PM
itz2qk4u's Avatar
The box in the glove box definately says lean .... 3 marks..then rich, not sure if someone has a old B & M superinjection set up in the car at one point or not...anyhow just looking to unhook the stock tach so it doesnt read at all...using a
tach dwell meter it read 200 rpms more than the autometer and almost 750 rpm less than the stock tach which would indicate the stock tach is causing problems as far as the Autometer tach reading correctly
Old Oct 5, 2009 | 06:59 PM
sideways's Avatar
Just unhook the stock tach outside on the firewall, inline by the tach filter is a single wire connector coming off the filter.
Can you get a pic of the fuel box?
Old Oct 5, 2009 | 07:17 PM
Budsjlm's Avatar
your running an hei distributor right?
Old Oct 5, 2009 | 07:38 PM
Budsjlm's Avatar
here is a pic of mine had easy access becuase its out of the car..your may look alittle different i have a
Old Oct 5, 2009 | 07:42 PM
Budsjlm's Avatar
aftermarket coil but check the wire that comes off there they may have spliced in it for the aftermarket tach if so remove it and rewire...
24_48Fan
Apr 19, 2008 07:48 PM
Krysden
Jan 11, 2008 04:49 PM
steptoe
Nov 7, 2006 12:33 AM
GreyMonte
Oct 10, 2006 06:08 PM
Boost
Apr 30, 2005 10:15 PM
