87 monte spark plugs underneath the exhaust manifold?
Old May 16, 2007 | 03:00 AM
g_bodymonte's Avatar
Default 87 monte spark plugs underneath the exhaust manifold?
i was wondering if anybody knew first of all, why the spark plugs on my 87 monte carlo 5.0L 305 v8 are underneath the exhaust manifold? and two, how i can get the wires from touching the exhaust manifold because that seemed to fix the sputtering problem when i replaced the plugs and wires and one was burnt in half from the manifold....any pointers? also do they make the manifolds out of a different metal that disperses heat quicker cuz i think the ones on there are like iron and they stay very hot for quite some time after the car is off. any help is appreciated. thanks.
Old May 16, 2007 | 06:37 AM
Laserblue06ss's Avatar
Default RE: 87 monte spark plugs underneath the exhaust manifold?
If the wires are too short they will be pulled too close to the manifolds.Some cheap aftermarket wires are known for this.If you get a good set of wires with adequate length,they should be able to clear everything.There should be grommets on the plug guides,so you can slide the wires to loop over the hot exhausts,and the grommets will hold the wires in that position.
Old May 16, 2007 | 03:02 PM
rj's Avatar
rj
I'm certain on a stock engine the plug wires are ran underneith.
When I got my '86 the plug wires were already ran over top of the valve covers so I left them like this when I installed new wires.
If you're looking for the pieces to keep the plug wires under the engine, check with Mike at Mike's Montes. He deals in 4th gen Montes. A nice guy to deal with.
[sm=smiley2.gif]
Old May 18, 2007 | 12:08 AM
ok sounds good. thanks man. i kno i have a good enough length its jus that they kinda rest on the manifold so i think those grommets should help. how do i get in touch with mike?
Old May 18, 2007 | 06:37 PM
rj's Avatar
rj
http://www.mikesmontes.com/
rgant_19
Feb 5, 2011 03:11 PM
nighthawk626
Nov 24, 2010 04:49 PM
moonlitmagik
Sep 14, 2009 02:05 AM
monte07
Jul 24, 2009 04:11 PM
pcp
Oct 18, 2007 04:46 PM
