75k Mile Service
Old Jan 16, 2014 | 12:28 PM
Autolite 605 Iridium I believe is the one step colder that you should use.
Old Jan 16, 2014 | 02:34 PM
Montelicious's Avatar
I use the 605 Coppers for my supercharged
Old Jan 16, 2014 | 04:03 PM
Since Keane is going to probably pay someone to do his plugs, I would recommend the Iridium just for the life of the plug.
Old Jan 16, 2014 | 04:17 PM
Agreed, probably going to split things up half myself half someone else. Have to get a quote to see how bad its gonna hurt.
Old Jan 16, 2014 | 04:43 PM
Found this information about plug heat ranges on 3800performances web site. I use Autolite 103's on my turbo app.
A general guideline for which spark plug heat range is right for your modified supercharged vehicle, are as followed:
- Use AutoLite 605's (one heat range colder) if your car is similarily modded like this: has a 3.40” supercharger pulley, CAI (cold air induction) setup, and a lower-temp thermostat.
- Use AutoLite 104's (two heat ranges colder) if your car is similarily modded like this: has a 3.25” supercharger pulley, 1.80:1 or 1.90:1 rocker arms or very mild cam, CAI setup, lower-temp thermostat, exhaust headers, cat-back exhaust system, and reprogrammed PCM.
- Use AutoLite 103's (three heat ranges colder) if your car is similarily modded like this: has a 3.0” supercharger pulley, 1.90:1 rocker arms or aggressive cam, CAI setup, lower-temp thermostat, exhaust headers, cat-back exhaust system, port and polished supercharger housing and/or throttle body, and reprogrammed PCM.
Old Jan 16, 2014 | 07:24 PM
I'm kind of in the middle, as i'd like to change plugs and prepare for the future, and i'd like to do a plog, downpipe, tune, and maybe drop pulley sizes. So it's a mix between 605's or 104's i'd say.
Jan 18, 2014 04:49 AM
RickCoMatic
Feb 1, 2010 11:40 AM
GSchroeder
Sep 25, 2009 07:57 AM
Laserblue06ss
Dec 7, 2007 10:29 PM
MonteCarlo04SS
Nov 24, 2004 11:47 AM
