Opinion Needed: 5x114.3 bolt pattern compatible with 5x115?
Old Nov 29, 2020 | 08:47 PM
ThunderSlug's Avatar
Default 5x114.3 bolt pattern compatible with 5x115?
So I've been looking for new wheels for my Monte, and for some reason the only place with good options/prices, CARID, only has wheels with the 5x114.3 bolt configuration. My Monte has a 5x115 bolt pattern and I noticed that there is quite a dispute on the internet if it's ok to use them. I will also note that CARID says that the 5x114.3 wheels are "compatible" with my car. I saw some people say that it's fine as long as I use hub-centric rings, and I think the installation kit comes with them.
I'm planning on getting 18" diameter 8" wide wheels with 245/45Z R18 tires.
Here's the link to the wheels: https://www.carid.com/motegi-racing-...pe-859997.html
Old Nov 30, 2020 | 08:53 AM
Sounds like you already did the research.
Run them at your own risk. You know it's not the fully correct bolt pattern, there COULD be added stress on your hub and studs. If they snap, you know why.
Old Nov 30, 2020 | 09:48 AM
nitehawkjcb's Avatar
I agree with Chibi. There could be added stress, which could very well damage bearings or studs. That being said, I run 5x114.3. Many others run that bolt pattern, one guy from way back ran 12's in the quarter mile regularly on Mustang rims with slicks.
l0gitech87
Mar 7, 2014 11:40 PM
Mattz LS
Jun 30, 2011 01:28 PM
bonang
Feb 25, 2008 09:36 PM
1988montess
Oct 10, 2007 07:49 PM
CHOWEE21
Aug 29, 2006 04:58 AM
