Any One Rinning 5x114.3
Old Jun 29, 2011 | 01:59 PM
Mattz LS's Avatar
Default Any One Rinning 5x114.3
anyone running wheels that are 5x114.3 on there monte? if so how is it? anyvibration?
Old Jun 29, 2011 | 02:50 PM
Paul1965's Avatar
I don't trust it myself, but check with Silverbullit. He's got a set of wheels off a Stang on his.
Old Jun 29, 2011 | 03:08 PM
They will bolt up, but I don't recommend them to people as you risk breaking studs with added stress.
Yes this is a big debate topic and I am NOT starting the debate, I will just recommend if you CAN get the proper 5x115.
Old Jun 29, 2011 | 03:12 PM
Mattz LS's Avatar
well I been debating because I have a set of 18s with brand new rubber off my ofther car that are 5x114.3 I have been on searching for some 5x115 wheels
Old Jun 29, 2011 | 03:25 PM
Personally I wouldn't do it.
Old Jun 29, 2011 | 03:58 PM
Its been done quite a bit and not too many problems have occurred that I've read of, I'm not saying do or don't do it but it can work
Old Jun 29, 2011 | 04:26 PM
mrl390's Avatar
3 years with mine and no problems. Thats 114.3x5 AND a 5/16 spacer with no problems.
Old Jun 30, 2011 | 10:53 AM
RickAKATed10's Avatar
Photobucket
Didn't have a problem on my car either.
Old Jun 30, 2011 | 11:21 AM
Boxman420's Avatar
i run them also.. no problems. no vibrations. i hear it can cause your struts to bend but i have only had mine for about 8 months. but no problems as of right now
Old Jun 30, 2011 | 12:20 PM
Paul1965's Avatar
Running a different bolt pattern wheel won't affect your suspension. You do however run the risk of putting too much side stress on the lug studs which could cause them to shear off.
