3.8 Series II Engine
Series II(1995-2005) LS36
Introduced in 1995, the Series II is quite a different engine. Although the stroke for the 3.8 L engine remained at 3.4 in (86 mm), and the bore remained at 3.8 in (97 mm), the engine architecture was vastly changed. The piston connecting rods were 1 in (25 mm) shorter, so the crankshaft was redesigned. A new intake manifold improved breathing, and a new cylinder head had larger valves. The result was 205 hp (153 kW) and 230 ft·lbf (312 N·m), better fuel economy, and 26 lb (12 kg) lighter overall weight.
The 3800 Series II was on the Ward's 10 Best Engines10 list for 1995 through 2005.
L36 Naturally Aspirated
The L36 was the first Series II version of the 3800. It has a 96.52 mm bore and 86.36 mm stroke for 3.8 L (3791 cc) of displacement. Power is 205 hp (153 kW) and torque is 230 ft·lbf (312 N·m). It was first introduced in 1995.
Over the years the 3.8 V-6 also benefitted from the latest in electronic engine management, and such refinements as improved combustion chamber and piston design. In the process it evolved into a very economical and reliable powerplant.
The 3800 Series became the standard workhorse engine for many of GM's cars.. It is virtually as smooth and quiet as a V-8, and has adequate power: 205 horsepower normally aspirated, and 240 supercharged.
In the early 21st century there is no doubt that the 3800 Series is an old design with its cast iron construction, and pushrods operating two valves per cylinder. In today's high-tech world GM's venerable V-6 will ultimately be replaced. And when it is, it will leave behind a remarkable history.
I posted the below questions to solicit information on the L36 3.8 Series II Engine.
I hope that it will help myself[8D] & forum members![Wink](https://montecarloforum.com/forum/images/smilies/wink.gif)
![Big Grin](https://montecarloforum.com/forum/images/smilies/biggrin.gif)
on anticipated problems
with this engine. If you have another series engine, please start another
thread for your type series engine.
`ok[:-]
1. Who has the highest miles on a 3.8 Series II engine ? (1995 - 2005)
--Please state, if it's SuperCharged in your post--
2. What problems have you had with this series V-6 ?
Example: (Fuel Pump, water pump, alternator, transmission, etc.)
3. How many miles, when this occurred ?
4. Approxmate cost for stated repairs ?
Example reply: (Battery failed at 38,000 27 months after purchase., Transmission
replaced at 134,000 in a 2000 Monte that was abused) or (not abused) Cost: $1800.
Please state how it was maintained: Excellent, Good, Bad......
Please post/share your knowledge & information. This forum will only be as good as the members make it.[8D]
Thanks for reading &
I hope that U post a reply
Below link has information on all Series:
http://en.wikipedia.org/wiki/Chevrolet_Monte_Carlo
Click 2 Enlarge[:-]
[IMG]local://upfiles/714/062DB30559C44E5DA7A9BFBC25D9382D.jpg[/IMG]
![EEK!](https://montecarloforum.com/forum/images/smilies/eek.gif)
![Smile](https://montecarloforum.com/forum/images/smilies/smile.gif)
Click 2 Enlarge[:-]
ORIGINAL: SpaceRider
The 3800 Series II was on the Ward's 10 Best Engines list for 1995 through 1997.
The L36 was the first Series II version of the 3800. It has a 96.52 mm bore and 86.36 mm stroke for 3.8 L (3791 cc) of displacement. Power is 205 hp (153 kW) and torque is 230 ft·lbf (312 N·m). It was first introduced in 1995.![EEK!](https://montecarloforum.com/forum/images/smilies/eek.gif)
post and ask your questions.![EEK!](https://montecarloforum.com/forum/images/smilies/eek.gif)
Below link has information all Series:
[IMG]local://upfiles/714/6B466A78C9294A36ACE2C50E94FD120E.jpg[/IMG]
2. Both the bonneville and grand prix had upper intake failure. The Bonneville had an alternator replaced. Nothing so far on the Monte
3. Grand Prix had 150,000 or so and the Bonneville had 142,000(UIM) and 138,000 for the alternator
4. Cost was right at $240 for both with me doing the work(UIM). That included plugs, wires and oil change. The alternator was $149. All three have meticulous service records. Very well maintained, all run synthetic oil that is changed every 5000 miles. The grand Prix is beat on pretty regularly.
To me once the upper intake is dealt with these motors are one of the best out there. From what I have seen being a mechanic there are very little issues with them. The only other common issues I have seen on a regular basis is the crank sensor/ignition modual problems.
Hope this help ya.
Hey Chris,
Thanks for your post, knowledge & time. It's exactlly the information
I was seeking.
I enjoy reading your post..&..glad U R a member.
I hope that other members post their information.[&:]
I was seeking.
i replaced the battery on my car this year it had 28,000 on it it is a 03 SS
I changed it out to a optima yellow top for the going rate of 175.00 with shipping to GErmany.
Works great runs smother and seem to not have the miss that was there befrore.
Mine has pretty much been trouble free, so far.... (knocks on wood)
The stealership replaced the ISS around 26K along with the alt at the same time, I did not like the noise it was making and insisted they change it out before the warranty expired.
see i tried to get them to replace or repaint the counil in mine due to it starting to rub past teh rubber coating on it. they refuse to do it here. they say it is normal wear and thrfore i have to live with it.
the biggest grip i have is the rotors are warpping on it. So i have replaced them twice now. Next time i will get something like willow wood or bear brakes and rotors to put on to it. and be done with it.
Part of that is alot of mountian driving here and also high speed and long stops here.
that and ever german in the country stops and waits for anyone on the side streets to get in front of them .
Thier right of way is if your on the right and trying to get out to the main road the main road yeilds for you to do so.
Cant tell you how many times i have almost assholed a damed beamer here for it.
ihave 43,000 on my monte right now it had a the water pump replaced at 27,000 and its fixing to get the ac compressor replaced withint the next week or so
im pretty heavy one the pedal btu i run synthetic and chage it every 5k i havnt had any drive ability isses out of it though
