Info: 2002 montecarlo ls
Old May 15, 2022 | 10:20 PM
2002montecarlols's Avatar
Default 2002 montecarlo ls
Hey guys I'm new here I got a 2002 montecarlo ls no start tried the whole 10 min thing nothin security light will turn off after I do the 10 min thing then I go to start and nothin when I bought the car it started up fine I noticed the pcm fuse is not getting anything it's not burnt up I don't wana take it to a dealer any ideas???
Old May 16, 2022 | 07:02 PM
I am concerned with two items:
1. - If you are getting the security indicator and it stays active for 10 minutes, then you have a security event. And you have to repeat that cycle about 3 times without removing the key from the ignition. There are full instructions in the FWD Tech section.
2. - I am not sure when that PCM fuse would be energized. It might rely on the position of the ignition switch.
Old May 16, 2022 | 07:10 PM
I have tried that 3 times like 10mins on then off for 10seconds 10mins on and off and on and off and it will go out then when I tried to start nothin it was a barn find and it started right up when the guy sold it to me I have no clue on wtf it could be I have read everything about these things I had one befor this car had the same problem did the 10 min thing and it worked
Old May 16, 2022 | 07:11 PM
I also have put a new ignition switch in battery hooked it up to jumpers checked all fuses
Old May 16, 2022 | 07:19 PM
Old May 20, 2022 | 10:54 PM
I uploaded the actual relearn procedure from the shop book (I find it to be well worded). Compare this to what you have been attempting (and see if you have any deviations from this, if so that deviation could be messing with the relearn). ALso are some tips I have found helpful that I personally added to the end of the document.
The security light staying on to me is pin pointing something failing with the passlock system. Any chance you have an aftermarket remote start installed??
File Type: docx
Old May 25, 2022 | 05:30 PM
I don't know I bought the car like this dint come with a fob just one key and I'll look into your vid
Old May 25, 2022 | 05:32 PM
Sooo last time I tried that the security light went off then went to start and nothing also thank you for your help
Clint Evans
Apr 3, 2021 10:45 PM
batmans_mc
Sep 13, 2020 08:23 AM
Rodney Washington
Jul 22, 2018 05:49 PM
HIxArsenaL
Feb 16, 2013 09:32 PM
Jsim465
Mar 15, 2012 08:36 PM
