1998 a/c vent problem
Old Aug 28, 2004 | 02:20 AM
redneckmc's Avatar
Default 1998 a/c vent problem
when i run the a/c on my 98 mc z-34 it wants to blow the air threw the defrost and to the floor. sometimes when its idling it blow alittle bit out of the dash vents, it dosnt matter what setting i put it on. does anyone have any ideas on what might be wrong? thank you for any info.
Old Aug 28, 2004 | 10:28 AM
montejass's Avatar
Default RE: 1998 a/c vent problem
Hello Redneck,
Your problem most likely is due to a vac problem somewhere in the A/C system. Your A/C vent control system uses vacuum to operate the vent doors. I would start by pulling your dash apart to check those vac lines for leaks. Secondarily, as you have your a/c system apart check each vent door's mobility. It may simply be that something is just stuck. Post back and let us know what you find...
TVW
Old Sep 2, 2004 | 11:04 AM
redneckmc's Avatar
hopefully i can take a look at it this weekend , ill let know what i find wrong with it. thank you for the info.
Old Sep 29, 2004 | 09:56 PM
redneckmc's Avatar
i found a vacum line by the battery that had been broke off, i couldnt find were it lead to so i used electricle tape to plug it. now my a/c works like it should.
Old Oct 1, 2004 | 09:39 AM
montejass's Avatar
Cool.... I am glad you were able to trace down your problem!!! Vacuum lines become brittle and require replacement after a period of time which should be a high focus item after 4-6 years.
TVW
Mechanically Declined
Jan 19, 2013 01:38 AM
simdog765
Nov 28, 2011 10:38 PM
yzfman98
Oct 25, 2010 02:46 AM
70monte1
Aug 17, 2010 05:19 PM
misio66661
Jul 8, 2009 05:45 PM
