3rd Gen ('78-'80): 1979 monte carlo
Old Jul 2, 2012 | 06:49 AM
jhnsffrd's Avatar
Default 1979 monte carlo
need help. Got a garage find '79 Monte Carlo with a 267 motor. After sitting for ten years I got her running farly well except for some loud lifters. 89,000 miles on a perfect body and interior. Problem no brake peddle. Replace master cylinder, pedal still goes right to the floor and isnt losing any fluid from the system. Love this car, gonna be a beauty. Any brake techs with a suggestion where to turn? i was thinking air in the lines but they dont even pump up. Thanks for your help
Old Jul 2, 2012 | 06:59 AM
DE02Carlo's Avatar
When you replaced the Master did you bleed all the brakes at each wheel. If not I would start there. Even if the doesn't pump up leave the bleeders open until fluid comes out...as alway be carful not to get fluid on the paint.
Old Jul 12, 2012 | 01:20 PM
TheMonteMan's Avatar
did you check the brake lines? perhaps bad wheel cylinders?
Old Jul 12, 2012 | 06:54 PM
Zen's Avatar
Zen
Did you bleed the master cylinder before installing it.They will air lock some times if there not bleed right
Full_of_ Sole
Sep 5, 2008 07:01 PM
1979MONTE
Oct 15, 2007 09:53 PM
Charlie
May 9, 2007 09:09 PM
maximum98
Dec 27, 2006 12:21 AM
