'04 bogs down, when gas is pressed will not run - HELP!
Old 10-12-2011 | 03:43 PM
2004MonteCarl's Avatar
Just wanted to thank all those who chimed in on this thread. Most of the replies mentioned replacing the MAF sensor which I did, replaced with a new GM MAF, and so far it runs great. I should probably replace the IAC sensor as well, they're around $70 for an AC Delco replacement. Thanks again.
Old 10-12-2011 | 03:45 PM
Glad we could help
Old 10-12-2011 | 04:02 PM
Thrillseeker's Avatar
When replacing the MAF you might want to replace the O2 sensors as well so the computer will get the most accurate info to control the engine. Especially if you had a bad MAF. The computer uses the MAF and O2 sensors together.
nicks_monte
04-04-2014 12:56 PM
MonteLSV6
08-21-2013 02:33 PM
Snobird
05-06-2013 06:31 PM
superrod29
03-08-2012 11:15 PM
06mistreSS
03-07-2012 09:33 AM
Quick Reply: '04 bogs down, when gas is pressed will not run - HELP!
