6th Gen ('00-'05): 01 Monte SS
Old Jun 29, 2020 | 03:29 PM
JLUV916's Avatar
Default 01 Monte SS
While idling or running, my car has a surge or misfire and will sometimes shut off when I come to a complete stop. Could that be the ECM or a bad fuel injector or something else? I already had a full tune up and oil change. Thanks for your advice.
Old Jun 29, 2020 | 05:07 PM
Could be either (although pcm is extremely unlikely), could be something else altogether (MAF, O2, icm, etc). You need to gather some diagnostic info on it to figure out what's going on. No one can tell you exactly based on the extremely limited info presented here.
Do you have a scan tool that can read engine sensors & engine codes? That's going to be step 1 to start figuring out what's broken here.
Old Jul 30, 2020 | 09:31 PM
Justin Knight's Avatar
Sounds like a dirty MAF sensor. Clean that and if the issue is still there change the fuel filter and/or check the fuel pressure.
Old Jul 31, 2020 | 07:49 AM
Unplug the MAF first and see if the problem goes away.. If not, then try cleaning it. If not, its something else lol..
Old Aug 9, 2020 | 08:57 PM
JLUV any solution?
tylerh0717
Jun 4, 2015 09:44 AM
BlacknChrome
14
May 16, 2013 08:59 AM
drock2384
Oct 20, 2010 09:04 PM
menaja19
14
Jan 2, 2008 09:21 PM
malletboy
May 20, 2006 10:30 AM
