Mod Guide: 2000 Monte Carlo Amp Bypass
Old 04-11-2010, 07:56 PM
Enzo354's Avatar
STILL SLOW
Default 2000 Monte Carlo Amp Bypass
If your amp is going bad in your car, take both clips on the am, and cut all the wires. Leave some left if you ever feel like going back to a stock amped system.
These will be hanging and free, tape them so nothing touches
Black
Purple
Thin white
Orange
Here are the connections you need to make *note this is a 2000, I have no idea on 2001 and up* Also there are 3 tan ones, so take your time and test each one out to make sure its the right one, dont go clamping right away.
I think my stock system sounds louder without the amp and works great. I have no idea on long term effects but for now I love it.
Old 04-11-2010, 10:17 PM
wow, I thought you were celebrating something, I guess you discovered a good thing with your non-amp now monte carlo?? like you said, what are the long term effects? I guess you will let us know!
Old 08-24-2010, 08:31 PM
Anyone know if this will work on an 01'? Buddy of mine crossed a couple of wires when hooking up my subs to the stock radio and fried the stock amp. Let me know please?
Old 08-24-2010, 08:37 PM
MillerMonteSS's Avatar
2010 Monte Of The Year
What the... Well, I've done worse. Glad it worked out for you though.
Old 08-25-2010, 09:06 PM
Enzo354's Avatar
STILL SLOW
Should work on a 01. I sat in the trunk and messed with them for about an hour and kept chaging the fade an balance to get the right ones.
Old 08-26-2010, 02:27 PM
Thanks. I do believe I'm going to try it today. Wired up some neon's yesterday so that's on the agenda for today.
Edit: It worked! Thank you very much. Months of riding around with no music was horrifying!!
Old 08-26-2010, 11:35 PM
Enzo354's Avatar
STILL SLOW
Glad I could help, and the no music thing sucks. Trust me I did, then fixed it, then xm went out.
Old 08-09-2011, 06:52 AM
Default works great
thanks enzo for the wire pic , works great
Old 09-09-2011, 01:30 AM
can i use this to tap into an aftermarket amp?
Old 09-09-2011, 01:55 AM
Enzo354's Avatar
STILL SLOW
Maybe, I'm not very familiar with them.
Quick Reply: Mod Guide: 2000 Monte Carlo Amp Bypass
