Repair Guide: How to change OnStar mirror lights
Old Feb 20, 2011 | 03:36 PM
Originally Posted by darkbb
will do! thanks dude
would this work??
http://tinyurl.com/6hexpas
thatll work fine
Old Feb 20, 2011 | 05:26 PM
MrChyes's Avatar
k...thanks dude !
Old Jul 28, 2012 | 07:25 PM
Chris s's Avatar
Default Mirror fogging
I have a 2000 Monte Carlo SS fully Loaded and my mirror keeps looking like there is a fog in it, There is the clear spot on the mirror and then in the middle it looks like a fog. Hard to explain. Any one else see or have this??
New Member from canada
Chris s
Old Jul 29, 2012 | 07:33 AM
03SSLE's Avatar
Quite a few people have had problems with their rear view mirror and had to replace it, so your problem is not uncommon.
The needle nose tip for removing the light bulbs earlier in this post is a good one, but when I need to remove bulbs in a tight spot I use a slightly different approach. I slide a piece of rubber hose onto the bulb, pinch the hose about an inch below the bulb and pull or twist/pull. Pinching the hose creates a suction inside it when you pull and prevents it from slipping off the bulb. This little trick has worked like a charm every time I've used it.
Old Jul 30, 2012 | 04:47 PM
Chris s's Avatar
Makes me mad, My old job I was at for 14 years we received and shipped all the parts for the Monte Carlo Built here in Oshawa, Ontario,Canada and now I have one and need all kinds of stuff haha.
Old Jul 31, 2012 | 09:07 AM
The mirror has auto-dimming properties, that is done by a special fluid called electrochromic fluid. On hot days if you don't leave your windows cracked, etc, the fluid can start to evaporate. This causes the "fog" look. Need to replace the mirror
I'm on my 3rd mirror because of this stuff, and I could actually use another If your turn off the dimming feature it should go away for now.
Old Aug 1, 2012 | 05:25 AM
Chris s's Avatar
Didnt know that Thanks!! I used to have a mirror from work before too!! GRRRR!!
Old Oct 16, 2012 | 07:53 PM
Monroe's Avatar
Monte of the Month -- December 2013
An easier way i found accidently is just wrap the tape around the bulb itself and pull the tape down, taking the bulb out with it!!
Old Dec 11, 2012 | 10:07 PM
Bait's Avatar
Thank you. Just wish I could of found this 7 months ago.
Old Jan 6, 2013 | 03:03 PM
brewcitymc's Avatar
duct tape trick around pliers worked great for getting these bulbs out! simple and no bulb breaking mess! got led's in mine now
