Mod Guide: Hid fog light install 2006-2007
Here is the How To Install For HID Fog Lights on 2006-2007 Models
Step 1: Unscrew Bolt in left corner and remove white plastic tab and pull the headlight out and set it to the side.
Step 2: The fog light is right underneath the headlihgt twist it and remove the fog light bulb.
Step 3: Use the cable that connects your old light bulb for the new H.I.D. Light Bulb.
Take the aligator metal clips and insert them to the cable that was connected to your light bulb meaning inside the blue connection piece, match up black with black and red with red.
Here are the light bulb and connection made
Take off the cover of your new H.I.D. Bulb
Here is your new bulb
Insert the bulb in the fog light housing
Here it is inserted in the housing
Place the box at the bottom and screw it in place use a bolt, screw and washer and secure it to the plastic piece of the bumper.
Now Your all done
Here is the finished Product!
12000K H.I.D FOG LIGHTS ON!
Now Your all done
RE: HID FOG LIGHT INSTALL
These Instructions are the same for your low beams, the only difference is the bulb size and where you decide to put the black HID boxes they complete the circuit so the lights work like they do.
The way you plug in the bulbs to the low beam light socket is the same.
When I do get projector Headlights I will do another do it your self post but they will be installed the same why I just did the fog lights.
You can go to youtube and search for HID Install and there are videos of every step, This is how I got my experience on this topic as well as learning the steps from a co worker at work that did his low beams and fog lights. Also the HID Kits do come with great Instructions.
I recommen Buying these Kits from The seller HID World on ebay. They cost about $100 for each set and includes shipping, I recieved them in less than a week.
Install time is about a half hour to an hour.
Enjoy
Enjoy
You can do the same, the concept is the same, your bulb size for a 2002 monte carlo fog light is 880
Click on this link and it will tell you all light info for your car.
http://www.sylvania.com/ConsumerProd...lacementGuide/
DAMN! THANKS FOR PIX AS WELL AS STEP BY STEP INSTRUCTION.
I'm currently in the process of ordering my highs,lows and fogs H.I.D's for my 06 SS. This thread will help out a lot now when I get them even though the guy will install them for free.
One question I didn't see or maybe u didn't bother to add...
But is there a way to take off the AUTO day light's?
Like when u 1st start the car how the headlights automatically come on in till u turn the **** left once n get that message on the cluster "DAYLIGHTS OFF"
I just don't want to be starting up my car and having to turn off the daylight's especially with HID's
