Repair Guide: 6 Gen Headlight Bulbs Replacement How-to
Old Nov 21, 2005 | 09:04 PM
Boost's Avatar
Photobucket
Default 6 Gen Headlight Bulbs Replacement How-to
Originally Posted By: ralphtrent
I used Sylvania Silver Star Bulbs : Purchased at WalMart $38 for a set (total cost $76)
High Beam 9005ST
Low Beam 9006ST
READ DIRECTIONS FULLY BEFORE YOU START
NEVER TOUCH A HALOGEN BULB WITH YOUR HAND, THE BODY OIL CAN DAMAGE THE BULB, USE A PAPER TOWEL
Step 1: Pop the hood
Step 2: On the driver side, to far right and rear of the head lamp, there is a whiteretaining clipthat locks the headlamp into place, just pull it up. (see pics 1 & 2)
Step 3: The sameclip is on the left of the headlamp. (see pic #3) Remove the black plastic shrowd above the clip by first pulling out the black plastic push pins.
Step 4: Pull the headlight casing out
Step 5: Pull off the weather proof cup from behind the low beam
Step 6: Reach in a turn the light bulb (I believe counter clock wise)
Step 7: Unlock the bulb from its wiring hardness, but lift up on the clasp
Step 8: With a paper towel, pull the light bulb out of the socket
Step 9: With a paper towel, put the new light bulb in and make sure it locks to the wiring harness.
Step 10: Put the weatherproof cup back on
Step 11: Replace high beams the same way if needed
Step 12: Put fixture back into place
Step 13: Replace the whiteclips on the right and left sides to lock the fixture in
Step 14: Test bulbs
Step 15: repeat steps for passenger side. NOTE: This side is a little tight and the fixture will not come out as much as the driver side did, DO NOT PULL OUT MORE THEN ALLOWED
Pic #1
Pic #2
Pic #3
Old Apr 22, 2010 | 03:05 PM
dspholmes's Avatar
good writeup
mairj40
Jun 4, 2012 11:02 AM
ralphtrent
Sep 26, 2010 12:25 AM
covenantl33t
Jun 20, 2010 09:28 PM
toasterlocker
Nov 17, 2009 03:51 PM
spike_monte
Nov 15, 2006 10:29 PM
