6 Gen Headlight Bulbs Replacement How-to
Originally Posted By: ralphtrent
I used Sylvania Silver Star Bulbs : Purchased at WalMart $38 for a set (total cost $76) High Beam 9005ST Low Beam 9006ST READ DIRECTIONS FULLY BEFORE YOU START NEVER TOUCH A HALOGEN BULB WITH YOUR HAND, THE BODY OIL CAN DAMAGE THE BULB, USE A PAPER TOWEL Step 1: Pop the hood Step 2: On the driver side, to far right and rear of the head lamp, there is a whiteretaining clipthat locks the headlamp into place, just pull it up. (see pics 1 & 2) Step 3: The sameclip is on the left of the headlamp. (see pic #3) Remove the black plastic shrowd above the clip by first pulling out the black plastic push pins. Step 4: Pull the headlight casing out Step 5: Pull off the weather proof cup from behind the low beam Step 6: Reach in a turn the light bulb (I believe counter clock wise) Step 7: Unlock the bulb from its wiring hardness, but lift up on the clasp Step 8: With a paper towel, pull the light bulb out of the socket Step 9: With a paper towel, put the new light bulb in and make sure it locks to the wiring harness. Step 10: Put the weatherproof cup back on Step 11: Replace high beams the same way if needed Step 12: Put fixture back into place Step 13: Replace the whiteclips on the right and left sides to lock the fixture in Step 14: Test bulbs Step 15: repeat steps for passenger side. NOTE: This side is a little tight and the fixture will not come out as much as the driver side did, DO NOT PULL OUT MORE THEN ALLOWED Pic #1 https://montecarloforum.com/upfiles/...7879608662.jpg Pic #2 https://montecarloforum.com/upfiles/...788F8CCC49.jpg Pic #3 https://montecarloforum.com/upfiles/...E6061D43FE.jpg |
good writeup
