ZZP Shift Kit
Old Nov 26, 2012 | 05:17 PM
Bait's Avatar
Default ZZP Shift Kit
4t65e
Is this a good buy?
Also should you use the transmission filter they supply or stay with the AC Delco?
Thanks for your help.
Old Nov 26, 2012 | 07:34 PM
jd1101's Avatar
i like the shift kit stay with zzp filter reuse your trans pan gasket . easy install . use Dexron VI Transmission Fluid .
Old Nov 26, 2012 | 08:52 PM
Jomao_o's Avatar
How much is ZZP's shift kit?
There is a nice DIY write up over at GPONA.com...probably for under $30.
Old Nov 27, 2012 | 06:05 AM
I would NEVER recommend re-using a trans pan gasket. I normally pan drop, filter, fluid change about every 100K miles. In that time, rubber, paper or cork, the gasket takes a beating (some on the brink of beginning to seep fluid out). If you drop it, change it. If you don't like the one that came with your filter or kit, don't be cheap, buy one you are happy with.
Old Nov 27, 2012 | 06:28 AM
Bait's Avatar
Sounds good. I already have Mobil 1.
Old Nov 27, 2012 | 06:30 AM
Bait's Avatar
I picked up the kit for $20. It was 50% off for Black Friday.
Is there a direct link to the write up?
Old Nov 27, 2012 | 06:56 AM
Bait's Avatar
Don't worry I will be using a new gasket. Just wanted to ask cause I know there was debate over which filter to use.
If you want to you can come down and change it out this warm weekend.
Old Nov 27, 2012 | 08:27 AM
Jomao_o's Avatar
Not bad. When I changed trans fluids in the past I reuse the factory gasket, it was better quality than what I purchased at autozone.
Here is the link:
Grand Prixs Of North America • View topic - DIY Shift Kit For Under $10*
Old Nov 28, 2012 | 12:27 AM
S.O.G.'s Avatar
Hey JOMAO_O, i remember on an older posting u commented of mine we had the exact same set up...have u ever dynoed or ran ur monte in a quarter? I finished up my whole exhaust system like 2 months ago and now i have everything ready to drop to a 3.4 pulley u gotta get one the pulley looks so sexy even off the s/c haha
Old Nov 28, 2012 | 01:06 AM
Bait's Avatar
[QUOTE=Jomao_o;510486]Not bad. When I changed trans fluids in the past I reuse the factory gasket, it was better quality than what I purchased at autozone.
Here is the link:
Grand Prixs Of North America • View topic - DIY Shift Kit For Under $10*[/QUOTE
That's an awesome write up. Going to need to order the spring as well.
