ZZP Oversized Radiator
Well apparently i pissed someone off real bad and they put a screwdrive or something through my radiator a couple times now it leaks everywhere and my car cannot be driven. I saw on zzp they have a radiator for 200 is this radiator worth it. Also how long would this take to install myself?
Never had one out. But I can't imagine it should be too bad. Maybe an afternoon if you're like me. DON'T forget to bleed the coolant system of air bubbles. There is a bleeder on top of the thermostat housing.
Hey check out these 2 links. They might help you some.
http://www.clubgp.com/newforum/tm.as...mode=1&smode=1
killerBee
Jul 1, 2018 02:14 PM
dgm
Apr 18, 2015 09:04 AM
6th Gen ('00-'05): Oversized Radiator?
Johnlh97
Mar 6, 2015 04:24 AM
01, 2006, aluminum, carlo, install, installation, leak, monte, oversize, oversized, radiator, radiatormontecarlo, spaces, transmission, zzp
