Zzp 1.0 pcm
Old Jul 28, 2009 | 06:57 PM
Default Zzp 1.0 pcm
I ordered one of these and I will be receiving mine tomorrow. I have been searching the threads and have not heard good things about the security issue with this canned PCM from ZZP and Montes. I have printed out the instructions on how to do a security relearn. Now I am scared because I can't afford to have this car not run right. Does anyone have any suggestions for me? I will do the install tomorrow and I guess if I have any problems you will be hearing from me - probably in tears. All I want to do is to have the 0402 code gone - but I don't know anyone in my area with an HP tuner.
Old Jul 28, 2009 | 07:19 PM
MonteDriver's Avatar
thats the EGR code right?
Old Jul 28, 2009 | 08:39 PM
sickofsoyo's Avatar
bought a ZZP 1.0 for my topswap, bad core... P1670, make sure it isnt throwing any codes before you send them your core.
Old Jul 28, 2009 | 08:46 PM
OK - I have a scanner so I can test it - I'm not going to send back my PCM until I know I am not going to have any problem with the new one they send me.
Old Jul 28, 2009 | 09:07 PM
P0240: Catalyst System Efficiency. The stock PCM dosn't like the high flow cat - it won't do any damage and I have a scanner to erase the code temporarily, but if I am to pass emissions, the code has to be permanently gone - tuned out.
Old Jul 28, 2009 | 09:42 PM
Toasty's Avatar
are you talking about a security relearn or the Case relearn procedure for the CPS?
Old Jul 28, 2009 | 09:58 PM
I am talking about the security relearn
Old Jul 28, 2009 | 10:04 PM
Toasty's Avatar
These are the instructions you have for the security relearn, right?
1.) Attempt to Start (Key to Run) NOTE : Car will not start
2.) Release key to 'ON' position
3.) Wait ~11 minutes (or until Security Light INdicator) turns off in message center.
4.) Turn Key off and wait 30 seconds.
5.) Repeat 1 - 4 until car starts (usually 3 cycles)
Old Jul 28, 2009 | 10:21 PM
oh great i'm about to have a high flow cat installed
Old Jul 28, 2009 | 10:31 PM
Toasty's Avatar
you could opt for an o2 simulator instead of swappng the PCM...
