Zzp 1.0 pcm
I ordered one of these and I will be receiving mine tomorrow. I have been searching the threads and have not heard good things about the security issue with this canned PCM from ZZP and Montes. I have printed out the instructions on how to do a security relearn. Now I am scared because I can't afford to have this car not run right. Does anyone have any suggestions for me? I will do the install tomorrow and I guess if I have any problems you will be hearing from me - probably in tears. All I want to do is to have the 0402 code gone - but I don't know anyone in my area with an HP tuner.
thats the EGR code right?
bought a ZZP 1.0 for my topswap, bad core... P1670, make sure it isnt throwing any codes before you send them your core.
OK - I have a scanner so I can test it - I'm not going to send back my PCM until I know I am not going to have any problem with the new one they send me.
P0240: Catalyst System Efficiency. The stock PCM dosn't like the high flow cat - it won't do any damage and I have a scanner to erase the code temporarily, but if I am to pass emissions, the code has to be permanently gone - tuned out.
are you talking about a security relearn or the Case relearn procedure for the CPS?
I am talking about the security relearn
These are the instructions you have for the security relearn, right?
1.) Attempt to Start (Key to Run) NOTE : Car will not start 2.) Release key to 'ON' position 3.) Wait ~11 minutes (or until Security Light INdicator) turns off in message center. 4.) Turn Key off and wait 30 seconds. 5.) Repeat 1 - 4 until car starts (usually 3 cycles) |
oh great i'm about to have a high flow cat installed :(
Originally Posted by MonteDriver
(Post 147862)
you could opt for an o2 simulator instead of swappng the PCM... |
