Z34 crankshaft position sesnor
Old Aug 22, 2005 | 12:51 AM
jet404's Avatar
Default Z34 crankshaft position sesnor
My problem is that when the car warms up it stalls and/or the RPMs go nuts. When I force it into gear and give it gas the car sound like it has VERY low fuel pressure. When I checked the injector pressure valve, after stalling, it barely had anything. I did some research and it showed that it could be the cam sensor or one of the crank sensors (but most likely the 7X). I checked my cam sensor and it wasn't it.
Does anyone know the location of the 7X crankshaft position sensor in a '97 Monte Carlo Z34 (3.4L DOHC V6)? All I know is that it’s on the firewall side of the rear engine block, but couldn't actually find it.
Any advice would be appreciated, especially if someone has experienced this.
Franks 03SS
16
Aug 15, 2024 09:24 AM
alkalinetri3o
Aug 18, 2020 12:24 AM
dgm
Apr 13, 2015 02:07 PM
erik2282
Apr 27, 2009 04:32 PM
alkalinetri3o
Apr 13, 2008 05:58 PM
