Yet another problem with my Monte
Old May 7, 2013 | 03:50 PM
LilSeanCB's Avatar
Default Yet another problem with my Monte
I bought my 2003 Monte carlo 1 1/2 years ago and man the people at the repair shop know me too well. My car is in there at least once every 3 months with something major to do on it. Thankfully I've had an extended warranty until july this year. That cost me $1900 when I bought the car, so far they have paid over $8,000 in repairs (car only cost $5500)
I'm having yet another problem that I'd rather fix myself since my deductible is kind of high so my problem started last night my car dies while I was at a stop light. Since then I've drove it a few times and once every couple minutes if I'm stopped or parked, my RPM will jump to 3,000 for a split second then go back down around 1,000...then jump again and go back down. It shifts hard sometimes so I thought I needed tranny fluid but not the case, I did however need oil so I added 2 quarts (it was really low) now my dipstick says the level it wayyyyy over but before I added oil it was about a half inch on dipstick.
I just don't know what to do anymore, when my warranty is up I'm screwed because this car has been nothing but a money pit. BTW the $8,000 was head gaskets, water pump, alternator, like 15 seals and gaskets, oil pan, starter, hub, labor cost, the list goes on
Old May 12, 2013 | 01:44 PM
ndaguanno's Avatar
When my moms 02 impala ls did the stalling, sometimes it bogged if you tried to kick it down, and the rpms jumped on her it was a bad maf. As for the transmission its probably the pressure control solenoid in the transmission, the original ones failed and the car would shift harshly. As for the oil I would get it changed or get the extra out of the engine, having to much is just as bad as not having enough. On my old car if I needed oil I would start out with a half a quart and go from there to avoid that.
Tadcaster
Oct 28, 2012 10:34 PM
Cowboy6622
Feb 12, 2012 09:51 AM
MonteSS2001
Jun 11, 2007 08:48 PM
HaRvArDaLe
Feb 14, 2007 10:18 AM
03pacecar
Nov 28, 2006 10:58 PM
