write up for alternator and power steering pump install?
matt, jack up your car and look under the power steering return line. there are 2 lines on top of each other. the top one is the return line and the bottom is pressure line. since you have the same setup as mine pacesh*tter and lowering spring. look and see if the return line is touching the pacesh*tter down pipe. mine did and the return line was leaking fluid badly.
thinking this is the case. filled up the fluid at my shop, then 4 days later has the same problem. had to refill it again today. gonna have my guys look at it again this friday. hopefully permanently solve the problem
nope, that wasnt it silver. had the car jacked up at my shop, and its my steering rack leaking fluid everywhere. gonna have to have it replaced. no bueno. i have to keep my ps fluid filled every 4 days just so i dont burn out the pump. anyone know a good place to get a cheap steering rack?
superrod29
Mar 29, 2013 02:22 PM
Thehead
Jul 14, 2009 09:39 AM
