Anyone have an alternator write-up 56k beware
Old Jul 13, 2009 | 05:52 PM
Thehead's Avatar
Default Anyone have an alternator write-up 56k beware
Hey guys, I've been searching for a bit and haven't had any luck. Does anyone have access to an alternator replacement write-up for a 3.4L 97 Monte Carlo?
Thanks
Old Jul 13, 2009 | 05:58 PM
01-ON-AIR's Avatar
do you need to replace it, or looking to remove it. more info please
Old Jul 13, 2009 | 05:59 PM
Thehead's Avatar
as stated I'm replacing it, so I'm removing the old one that doesn't work and installing a new one.
Old Jul 13, 2009 | 06:26 PM
01-ON-AIR's Avatar
i dont waste time, go get yourself a haynes repair manual @ your local auto parts store there like $20 and ther worth every penny.
Old Jul 13, 2009 | 06:40 PM
Thehead's Avatar
nvm, I found something.
http://60degreev6.com/forum/f72/how-...ernator-t24972
no reason to spend money you don't have. If anyone has anything better feel free to post it.
Old Jul 13, 2009 | 07:32 PM
The Popcorn King's Avatar
i have the book. give me a few mins and i will scan it.
EDIT.
Here are the scans.
I hope this helps you out.
Old Jul 13, 2009 | 07:51 PM
Thehead's Avatar
awesome, thank you sooooo much
Old Jul 13, 2009 | 07:59 PM
Your welcome. Anytime you need help with your 5th Gen, just post it up and if i can find the answer in the book. then i will post it.
Now mind you, there are somethings that the book doesn't have, so i would not be able to help like i did right now, but i am sure that others can help. I know that Bumpin is great when it comes the 5th Gens.
Old Jul 14, 2009 | 08:50 AM
I also have a manual that covers 5th and 6th gens on the 3.1, 3.4, and 3.8 NA
Old Jul 14, 2009 | 09:39 AM
Cut Throat's Avatar
I recently swapped alternators on my '98 3.1. It wasn't a difficult job, just a few problems I ran into.
1st, along the steel brake lines that run next to the alternator there is a plastic clip that holds both in place that is a major PITA to get off. I recomend using a skinny flathead screw driver to hold it back.
2nd, getting the nuts off the bolts from the brackets on the right side that are under the steel brake lines. You will need either a very versitle wrench or small and nimble hands. Other then that, it wasn't too hard to do. Hope that helped some.
2003supersport
14
Jul 11, 2010 12:32 AM
ns_monte
Dec 20, 2008 11:39 AM
HyperFox
Oct 8, 2007 04:50 AM
TrickRacin
Apr 28, 2007 12:31 AM
monteriderLS
Aug 7, 2006 02:53 PM
