WOT problem code P0300 crusing is fine though
Old Sep 4, 2010 | 12:25 AM
silver86's Avatar
Default WOT problem code P0300 crusing is fine though
Today I was in a passing lane and did a WOT run to pass and noticed the car felt flat at about 4000rpm and then it just held at about 5000rpm and wouldnt shift. Then the check engine light started flashing.
So to test it again I tried in 1st gear and it did about the same thing but then the light stayed on and I got a code P0300. When crusing the car runs fine its only doing it a full throttle. I just turned 157K on it, does anyone think it could just need plugs/wires? They havent been changed yet but as I stated other than full throttle it runs fine so I was thinking spark blowout from worn plugs...Any advise before I start dunping money on it would be appreaciated.
Thanks
Old Sep 4, 2010 | 01:44 AM
PacerSS's Avatar
Clean MAF, Plugs, wires, fuel filter, ICM
In that order replace/do them until the problem goes away.
Old Sep 4, 2010 | 08:01 PM
silver86's Avatar
Just a quick update...I cleaned the MAF, changed the plugs/wires and was still doing it. After all day of messing around trying to figure it out, it turned out to be a clogged cat. Runs great again!
Old Sep 4, 2010 | 11:13 PM
PacerSS's Avatar
Dammit, I'm sorry man, I totally forgot about that issue. Sorry again. I should've mentioned that.
Old Sep 4, 2010 | 11:45 PM
Justin's Avatar
[quote=PacerSS;260506]Clean MAF, Plugs, wires, fuel filter, ICM
mine did the samething a few months ago and it was the cat and it was plugged. but a good thing to that its cover for 10years or 120000 miles that was cool
04IntimidatorSS
Oct 15, 2016 09:02 PM
Chevy03
Jun 17, 2013 10:53 AM
nitehawkjcb
Apr 13, 2010 11:49 PM
fever42
Feb 12, 2009 07:37 PM
drayven
May 12, 2007 09:43 AM
