WOT problem code P0300 crusing is fine though
Today I was in a passing lane and did a WOT run to pass and noticed the car felt flat at about 4000rpm and then it just held at about 5000rpm and wouldnt shift. Then the check engine light started flashing.
So to test it again I tried in 1st gear and it did about the same thing but then the light stayed on and I got a code P0300. When crusing the car runs fine its only doing it a full throttle. I just turned 157K on it, does anyone think it could just need plugs/wires? They havent been changed yet but as I stated other than full throttle it runs fine so I was thinking spark blowout from worn plugs...Any advise before I start dunping money on it would be appreaciated.
Thanks
Thanks
[quote=PacerSS;260506]Clean MAF, Plugs, wires, fuel filter, ICM
mine did the samething a few months ago and it was the cat and it was plugged. but a good thing to that its cover for 10years or 120000 miles that was cool
Chevy03
Jun 17, 2013 10:53 AM
nitehawkjcb
Apr 13, 2010 11:49 PM
