6th Gen ('00-'05): Won't crank/start when cold
Old Oct 24, 2013 | 06:07 AM
New2MonteNY's Avatar
Default Won't crank/start when cold
I bought my '01 from my son's uncle last year and he told me that there was a problem with it starting when it's cold outside, so he put a switch under the dash that's wired right to the starter, which he also had replaced. Last winter I had no issues starting it. Just yesterday and this morning (low 30s) it won't crank or start. When I push the button it fires right up, but only runs for a second and shut off and finally after a few starts it starts and runs like normal. Any ideas? Thanks.
Old Oct 26, 2013 | 02:58 PM
owens91's Avatar
this might not be a starting issue, this could actually be a fuel issue or a problem with the MAF...i believe what somee suggest to do is start the car without the maf and if it stays running thats the issue. hope this helps some
Old Oct 26, 2013 | 03:05 PM
Thanks for the reply...curious if that has something to do with my sometimes high idle too...Thanks ago..
Dubstepticon
Aug 19, 2015 08:00 PM
Knightwolf702
May 14, 2014 07:13 PM
sluvender
Feb 24, 2012 02:00 AM
SpaceAce
Dec 22, 2009 12:19 PM
ChevRev34
Feb 24, 2008 01:10 PM
