2000 SS Service Traction System, and Won't Crank
Old Feb 4, 2011 | 09:27 AM
sluvender's Avatar
Default -deleted-
-deleted-
Old Feb 4, 2011 | 09:31 AM
Security light illuminated?
Old Feb 4, 2011 | 09:32 AM
sluvender's Avatar
-deleted-
Old Feb 4, 2011 | 09:38 AM
Since so many things are going wrong, I'm afraid to say it could be something stupid like a bad ground, or even your BCM starting to go...
Usually the ABS Light and Trac Off light means a wheel hub assembly isn't sending the right information to the PCM and the car shuts those off automatically. But since everything else is lighting up, perhaps it's more serious.
I used to live in Hawley, PA (think about 45 mins from Scranton) Now I'm down in Elkins Park. I'm always driving through Lehigh Valley (Rt. 22 -> 33) when I visit my parents :P
Old Feb 4, 2011 | 09:53 AM
sluvender's Avatar
-deleted-
Old Feb 8, 2011 | 01:28 PM
sluvender's Avatar
-deleted-
Old Feb 8, 2011 | 02:14 PM
I'm sorry to hear!
Old Feb 8, 2011 | 03:08 PM
JerryD's Avatar
Ouch. Yeah, it kinda sounds that way...
Well, if you can drive on up to Hazleton, Hazle Auto Parts (http://www.hazleautoparts.com/) has 'em for $25. I just looked on car-part.com to see prices. I have no idea if this is doable for you, just thought I'd throw it out.
Good Luck!
Old May 18, 2011 | 11:59 PM
mwchavo79's Avatar
Default same problem
your story is exactly like mine with a 2002 Monte carlo SS. started with the traction control lights. then the turn signal buzzing. now it starts after 15-45 min of constant key turning. nothing, nothing, nothing, and then all of a sudden it turns over and starts.
let me know if you replaced the bcm and if it fixed your problems. i would really like to find out. I've seen other similar posts which state that it could be the ignition switch or pcm as well.
Old Feb 24, 2012 | 02:00 AM
Redline29's Avatar
old post and it sounds exactly like my problem....so what was the conclusion?!?!
Jokers1995
Aug 4, 2014 11:42 AM
Jokers1995
Jul 31, 2012 09:11 AM
strypergt
Sep 6, 2011 10:37 AM
shock081
Mar 18, 2010 09:23 PM
04superjr
Mar 21, 2009 12:52 PM
