Why does my Monte do this?
Old Sep 24, 2010 | 07:40 PM
jhornekm's Avatar
Question Why does my Monte do this?
We just put a transmission in it. It starts and runs fine, but when you are driving along at a steady speed the rpms move up and down slightly. It shifts through all the gears. Any help please?
Old Sep 24, 2010 | 07:43 PM
nitehawkjcb's Avatar
Could be the torque convertor trying to lock up. Make sure you have enough fluid in the transmission. If you do... you may have a bad TC.
Old Sep 24, 2010 | 07:47 PM
jhornekm's Avatar
how many quarts does it hold?
Old Sep 24, 2010 | 07:48 PM
jhornekm's Avatar
the torque converter came w/ the tranny
Old Sep 24, 2010 | 07:50 PM
I think the transmission holds 7 quarts I believe. Just check it with your dipstick. And regardless if the TC came with the transmission, it may still be bad. Unless you bought a brand new transmission, which I doubt.
Old Sep 24, 2010 | 07:54 PM
jhornekm's Avatar
It was used, but had low miles on it. Is there any way to test a torque conv?
Sorry so many ??
Old Sep 24, 2010 | 07:56 PM
You're good, you find answers by asking questions. I don't know of any way to test the TC, but if it's after you transmission has shifted into 3rd gear and goes to shift again, then your problem occurs, chances are that it's your TC.
Old Sep 24, 2010 | 07:59 PM
jhornekm's Avatar
Thanks for the advice! Have a good night..
Old Sep 24, 2010 | 08:03 PM
No prob. Hope I helped at least a little.
Red Monte Carlo
Nov 27, 2016 07:39 PM
Aug 31, 2013 04:54 AM
Brian Kolecke
Jun 24, 2013 08:53 PM
Budsjlm
Feb 15, 2011 12:21 PM
augi
Feb 13, 2011 08:15 PM
