Is the Whipple supercharger good?
RE: Is the Whipple supercharger good?
yes, yes it is heres why:
If more power is what you crave…Whipple Superchargers has the solution…heart-stopping acceleration, complete bolt-on packages, emissions legal supercharger kits that boost power up to 60%. By utilizing the Whipple Twin Screw Supercharger, we provide the largest effective power gains, while maintaining safe, trouble-free operation. The Whipple Charger gives you the unique combination of maximum power at low rpm’s for incredible drive-ability while still providing ultra high efficiency for top-end horsepower. Just squeeze the throttle and the engine responds immediately, from idle to redline. the thrill ride never stops!
The results are breathtaking…0-60 times drop dramatically, up to 60% power increases throughout the operating range, incredible throttle response, emission compliance and virtually maintenance-free. How is this possible? It’s the integration of the Whipple Twin Screw Supercharger and Whipple's superior engineering that makes it all possible.
Over the past fifteen years, Whipple Superchargers has risen above the competition to become the true supercharging leaders with proven performance, reliability, customer service and quality. Other companies claim to be leaders with incredible power levels, but the results speak for themselves.
[ul][*]Positive displacement twin screw design has the highest efficiency of all superchargers including roots and centrifugal [*]Higher efficiency means more power at all rpm levels[*]Unique Whipple twin screw design provides the largest power gains across entire rpm range[*]Similar screw compressor design as the Ford GT supercar[*]Same screw compressor technology that Mercedes has utilized on all their latest vehicles including the 600hp McLaren SLR, E55AMG, S55, CL55, SLK32 and SL55[*]Dyno proven to produce more horsepower and torque than any other supercharger throughout the entire rpm range.[*]21st century fuel injection that has more processing power than the factory computer resulting in incredible drive-ability[*]Whipple designed air-bypass system for unsurpassed fuel economy[*]Commitment to quality and excellence[*]Astounding customer support from our well trained, performance enthusiast personnel[*]Nobody can compare to the OEM packaging and quality of parts Whipple provides[*]50 state emission compatibility[*]Unmistakable industry leading fit and finish[*]100% complete systems ready for an easy installation and trouble free operation[*]Systems consistently produce very low levels of noise, commonly undetectable[*]True technological leader in supercharger industry [/ul]
Every Whipple product goes through extensive research and development to ensure proper operation in all applications. Our standard development practice involves the measurement of over 100 parameters utilizing our own custom designed data acquisition computers. Measurements include individual cylinder air/fuel ratio from a true wide range Horiba sensor, individual cylinder pressure and cylinder combustion analysis as well as solid-state exhaust gas temperature. Our expert calibration team has over 15 years of OEM experience calibrating the most stringent emission standards such as Super Ultra Low Emission Vehicles (SULEV) and Zero Emission Vehicles (PZEV). No other supercharger company has a more advanced staff in computer technology and emsission friendly products. Every product gets extensive R&D time on either our DynoJet Chassis dyno, our Superflow engine dyno or our Land & Sea propshaft dyno. This ensures that you get maximum power from our product and long, trouble free operation.
Whipple Charger
Centrifugal
Turbo
Roots
Response
Awesome idle-to-redline rpm power. No lag.
Poor low-speed response, similar to "turbo lag."
Poor low-speed response. Turbo lag.
Good low to mid range power.
Driveability
Increased lugging ability in higher gears. Increased power throughout rpm range.
Must downshift to maintain boost level.
Engine Torque Curve
Virtually flat curve; ideal characteristic.
Often worse than uncharged engine at low speeds.
Wide range; fall-off can occur at high speeds.
Heat Buildup
Low; intercoolers are usually not needed.
High; may need intercooler
High; limits boost available.
Noise
Very low noise levels.
Typically very noisy.
Adiabatic Efficiency
70-80%
60-78%
60-75% Peak
40-55%
WHAT SEPERATES WHIPPLE FROM THE COMPETITION
SUPERIOR ENGINEERING
Our relentless commitment to creating products that exceed the cutting edge of design, performance and quality has given us the reputation as innovators and leaders in the high performance industry. Every Whipple product goes through extensive research and development to ensure proper operation in all applications. Our standard development practice involves the measurement of over 100 parameters utilizing our own custom designed data acquisition computers. Measurements include individual cylinder air/fuel ratio from a true wide range Horiba sensor, individual cylinder pressure and cylinder combustion analysis as well as solid-state exhaust gas temperature. Our expert calibration team has over 15 years of OEM experience calibrating the most stringent emission standards such as Super Ultra Low Emission Vehicles (SULEV) and Zero Emission Vehicles (PZEV). No other supercharger company has a more advanced staff in computer technology and emsission friendly products. Every product gets extensive R&D time on either our DynoJet Chassis dyno, our Superflow engine dyno or our Land & Sea propshaft dyno. This ensures that you get maximum power from our product and long, trouble free operation.
Whipple Charger
Centrifugal
Turbo
Roots
Response
Driveability
Engine Torque Curve
Heat Buildup
Noise
70-80%
60-78%
60-75% Peak
40-55%
Does anyone kno if the whipple supercharger is good also is it good for the price
However, asking if it is a good mod for a 3800 is a totally different question. Before you even begin to consider one, you must have:
headers, ported heads, a pretty big cam, an IC, a built transmission
Basically, if you don't already have a nearly maxed out M90 setup, then there is no point in putting a whipple on because you still have better $/hp mods to go.
If you do happen to have a fully built M90 setup- you really need to ask yourself why you want to do it. You will make less power than the turbo guys, you'll spend more money than the turbo guys, and you'll run slower than the turbo guys. Thats a very important point to understand. If your goal is all out power- a turbo setup is the only option. If you still are considering a whipple setup, then keep reading:
This is the original kit for the 3800:
http://www.wbodystore.com/grandprix/...-new-p-25.html
which still needed tons more money invested into it to make it work. It will never be made again in that kit form, and it is doubtful anyone ever will release a kit for it. Option A is to check www.clubgp.com/forum in the classifieds frequently to try and find a used kit- but keep in mind you will spend a ton more money making it work.
IMO, you should go to whipple and buy a raw 140AX and snout(no idea what these go for). Then call up a Yella Terra dealer (australian) and buy their lower intake manifold/intercooler for a 3800 to whipple 140AX (~$1100). Now you'll need an inlet adaptor to mount a throttle body to, but all the ones made are for rwd unless you can find one used on clubgp that someone is willing to separate from their kit-unlikely. PRJ performance is working on a adaptor for this, but it is not done yet. He is looking around $1000 for the adaptor, plus you need to buy a 90mm LSX style throttle body (~$400), and a 90* bypass valve from whipple (~$200). You can buy a pullies for the setup from South Florida Pulley HQ- they're a 1 off pulley that runs $125 each with a 3-4 week lead time. Also, if you don't already have aftermarket fuel rails- you'll need those to clear the blower $400.
Once you have all of that, the only part you'll still need is some tubing to connect the bypass on the two adaptors together, and for the PCV and such too, but its all little stuff. That is the best option for putting a whipple on your 3800.
As you can see- with the mods above, plus the whipple- you're quickly getting into a $10,000+ engine setup, and that alone is enough for you to be considering your other options. There are many other platforms that can go faster for much cheaper, but it all depends what you want to do.
If you have any questions, my monte is one of a handful of running, driving whipple charged 3800s- so feel free to ask.
