whining noise coming from alternator?
Old Jun 22, 2010 | 11:58 AM
2003supersport's Avatar
Photobucket
Monte Of The Month -- May 2009
Default whining noise coming from alternator?
hey guys, have a problem. started a few days ago, only happened some of the time. now its all the time. its like the alternator (at least thats where i think its coming from) is whining, its loud. it increases as i increase speed. i originally thought it was something rubbing against a belt, but its not. then i thought it might be a tranny part giving way, but when i popped the hood, the noise was very local around the alternator. i thought it could even be from the power steering pump but it happens before i even touch the wheel. anyone have any ideas? dead alternator?
Old Jun 22, 2010 | 12:04 PM
MAMONTE's Avatar
It could be the alternator, but I think more common on these cars would be the power steering pump. The power steering pump will whine even when you are not using the steering if it is bad.
Old Jun 22, 2010 | 12:09 PM
Take your belt off, and start spinning everything and see if it makes a sound
Old Jun 22, 2010 | 12:13 PM
Photobucket
whats the going rate for a power steering pump? and i might just have to do that blacksheep, but im trying to avoid it if possible. i got one giant belt since i have the ss m90 kit. its a fun one to get back on lol
Old Jun 22, 2010 | 12:17 PM
MAMONTE's Avatar
I think Autozone has the power steering pump for right around $100, and its really not to difficult to do yourself.
Old Jun 22, 2010 | 12:20 PM
Check the fluid first to make sure it's not just a little low.
Old Jun 22, 2010 | 12:31 PM
Photobucket
haha i was trying, but i cant seem to find the damn dipstick. i know its buried and its really small (thats what she said) sorry had too lol. its back on the firewall on the pass. side correct?
Old Jun 22, 2010 | 12:38 PM
MAMONTE's Avatar
LMAO!
And yes find the alternator, and then look straight down. Its below the alternator. Make sure the car is not hot either, or you WILL burn yourself getting to it. You have to unscrew the top, and the dipstick is on the cap. Then make sure you wipe it off, and fully screw it back on, and then remove it again to get a good reading of the fluid level.
Old Jun 22, 2010 | 01:26 PM
MJClemm
15
May 31, 2013 12:17 AM
silveradoman298
Apr 27, 2013 04:30 PM
mew20176
Nov 3, 2010 10:45 PM
Jomao_o
Dec 18, 2009 04:52 PM
MAMONTE
May 16, 2009 06:02 PM
