whats a good mod?
Old Feb 18, 2010 | 03:50 PM
would a magnaflow cat get rid of the u bend, does that one just bolt on and will i see a hp increase?
You need to slow down and read, I posted this just above:
However, you're trying so hard to find ways to make power- no one can suggest anything until you tell us all the engine mods you currently have, and how much you want to spend- then we can put you on track to what you can and should do.
Now, more specifically, back to your question:
A cat is not a ubend- so no, if you buy a new cat and replace your cat as is, then you still have a ubend and an otherwise stock downpipe. Sure you could have an exhaust shop do a ubend delete while they're installing the cat, there wouldn't be much extra work to it- but many shops are VERY against doing them for some reason (liability of the O2 sensor getting snagged on road debris I assume).
Does what one bolt on? You didn't link to anything, or give us a clue what we're looking for. Assuming you're just going to call up Magnaflow and buy a cat- of course it won't bolt up- the factory cat is welded in as part of the downpipe assembly. So obviously you'll have to get your cat cut out and the new one welded up.
Personally, I wouldn't waste my time- you're not going to gain hardly any power- its not a real big restriction unless your factory one is plugged.
Old Feb 18, 2010 | 03:56 PM
Wilco's Avatar
I disagree- if you buy a quality tuner like DHP PT or HPT, the risk is very minimal- and is almost completely user caused (ie unplug during a flash, let the car or laptop battery go dead mid flash, etc). While I don't think the tuner/programmer should be his next mod, a real tuner is not going to fry your pcm.
I knew you would, ! What caused my PCM to buy the farm was the Hypertech Power Programmer 3. I got the dealer's receipt to prove it. That's THE programmer I was TALKING about. I'll tell everyone and their mother-in-law not to buy one, but that's MY opinion from MY experience. I now have HP tuner and I'm very happy with it.(Although I'm still learning how to use the thing).
Old Feb 18, 2010 | 04:28 PM
No need to get worked up, I'm sure yours did fry the pcm- I was just saying that not every tuner/programmer is going to fry your pcm.
This is what I mean:
but stay away from the programmers
And hence why I always say I'd avoid any programmers except the proven ones like DHP or HPT- instead of making a blanket comment about all programmers being bad.
Old Feb 18, 2010 | 04:51 PM
Wilco's Avatar
! Not worked up, but making sure my spelling was correct. I have problems translating from Spanish to English at times and getting my point my point across can be trying sometimes.
Old Feb 18, 2010 | 05:14 PM
A cat is not a ubend- so no, if you buy a new cat and replace your cat as is, then you still have a ubend and an otherwise stock downpipe. .
okay well the cat im looking into has a plug in for teh o2 sensor and isnt the o2 sensor in the u-bend? so uh im kind of confused.
Old Feb 18, 2010 | 05:30 PM
Wilco's Avatar
In the picture you can see where the O2 sensor gets screwed on. That section is straight. That's where the U-bend used to be but in this DP it has been deleted.
http://www.partstrain.com/store/deta...on=Driver_side
Old Feb 18, 2010 | 06:02 PM
I bet he's looking at that crappy universal downpipe that magnaflow has their name on.
Old Feb 18, 2010 | 06:22 PM
no its not "crappy"! it was a direct fit oem replacement that was dicontinued. and to you montyss02 thanks for the link very helpful.
Old Feb 18, 2010 | 07:07 PM
Wilco's Avatar
Hey man, no sweat!
Old Feb 18, 2010 | 08:32 PM
If the cat you're looking at has a bung for an O2 sensor, then it is more than just a cat- its either a cat and ubend delete (which I've never seen for our cars- a part that just replaces from the cat to the rear downpipe flange)- or its a complete downpipe.
The thing in the picture posted above is a complete downpipe. If you were to buy just a cat as you were saying, this is all you would get:
DE02Carlo
Jun 7, 2012 04:18 AM
BlackRainSS
Dec 29, 2011 12:01 AM
Jon
Apr 20, 2011 10:58 AM
MFCL
Jun 1, 2010 07:29 AM
wht02monte
Feb 28, 2010 12:47 PM
