what are these connectors?
the first is on the 98 Z harness and have not where to plug in.
this one is on the body from the 96 Z and i think is plugged into the ABS
everything else is connected or accounted for... could i be missing part of a body harness?
In the first pic, are you seriously standing inside the engine compartment???
And in the second pic, I think you are missing a module (which may explain the where some of the wires go). You have a rail with a tab sticking straight up. There is a module that goes there and I believe a plug goes into it. But without having access to my Monte right now, tough to say for sure....
The wire by your alternator is an extra plug, I have the same one
The one by your transmission either goes to the connector going across the front of the valve cover area, or it's another spare. I have a few extra connectors by the tranny, but I have a modded GTP harness
2) all modules accounted for... on the L67 the evap is in the back there. but on the l36 the evap is upfront. egr, map are all accounted for.
Nas Escobar
Mar 30, 2015 12:23 AM
6th Gen ('00-'05): Butt Connectors on the PCM Harness
JC Colon
23
Oct 23, 2013 11:14 AM
