what spark plugs for zzp L36 supercharged setup
Old May 17, 2013 | 12:06 AM
NYGiantsfan's Avatar
Default what spark plugs for zzp L36 supercharged setup
hey so im about to install the zzp l36SC kit in a few days and they come with autolite 104 spark plugs, should i stick with them? or buy the stock ones? or does it have something to do with the heat range?
work done/working on currently
pcm modded (included in kit)
installing a 3" cat'd down pipe
k&n filter
Old May 17, 2013 | 05:46 AM
Use the ones it came with. They are colder plugs, which you need to run.
Old May 17, 2013 | 03:37 PM
PacerSS's Avatar
The 104's should be fine for your mod range.
Old May 17, 2013 | 04:21 PM
nitehawkjcb's Avatar
Agreed, 104's should do the trick
Old May 18, 2013 | 07:26 PM
thanks guys, will do. do y'all think they would have to be changed again if i put in headers incase of kr?
Old May 18, 2013 | 07:40 PM
Probably not, usually 104's are good until you add an IC or cam.
zipper
Jun 1, 2015 07:50 AM
NYGiantsfan
May 30, 2013 05:48 AM
NYGiantsfan
May 24, 2013 01:31 AM
my00monte
26
May 23, 2011 06:13 AM
360spence13
Nov 11, 2007 03:34 PM
