What RPM should the engine idle at?
Ok so my low oil pressure light is coming on every time i come to an idle. I noticed my car is idling above the 500 mark and fluctuates between 550-650. If i bring up the rpm's a bit the low oil pressure light goes away. Its been like this for 2 weeks now. any ideas?
There called idiot lights for a reason.
Have you done an oil change recently?
Maybe its time you did?... Is it possibly contaminated?.with antifreeze leaking into the oil.
Or maybe the sending unit is going bad?
Is it low on oil?...
