What RPM should the engine idle at?
Old Apr 12, 2013 | 04:51 PM
Lorenzo's Avatar
Default What RPM should the engine idle at?
Ok so my low oil pressure light is coming on every time i come to an idle. I noticed my car is idling above the 500 mark and fluctuates between 550-650. If i bring up the rpm's a bit the low oil pressure light goes away. Its been like this for 2 weeks now. any ideas?
Old Apr 12, 2013 | 05:01 PM
iMuf's Avatar
I have an 06' so I'm not sure if it would be any different. But I just checked out mine and after letting it run for a few minutes it idled around the 600 mark
Old Apr 12, 2013 | 05:06 PM
tps221's Avatar
thats super low the car should stalll around 500 rpm.... if it bouncing get a tune up
Old Apr 12, 2013 | 05:16 PM
Lorenzo's Avatar
I have pics, ill post them later.
Old Apr 12, 2013 | 05:42 PM
Should be around 7-800
Old Apr 12, 2013 | 06:19 PM
03SSLE's Avatar
When cold mine idles at 1,000 rpm (park), 800 rpm (drive) and 650 rpm (drive) when up to temperature.
Old Apr 13, 2013 | 02:04 PM
Lorenzo's Avatar
Ok guys, sorry power was out last night. I took a picture of it in drive and Park.
img0657 is drive and 0658 is park
Attached Thumbnails What RPM should the engine idle at?-img_0657.jpg   What RPM should the engine idle at?-img_0658.jpg
Old Apr 15, 2013 | 07:57 PM
Lorenzo's Avatar
do those pictures look good or bad?
Old Apr 16, 2013 | 05:53 AM
Looks fine to me, minus the oil pressure
Old Apr 16, 2013 | 06:29 AM
Question
There called idiot lights for a reason.
Have you done an oil change recently?
Maybe its time you did?... Is it possibly contaminated?.with antifreeze leaking into the oil.
Or maybe the sending unit is going bad?
Is it low on oil?...
