Opinion Needed: What gears should I get ?
Old Sep 1, 2014 | 07:29 PM
03vaderSS's Avatar
Exclamation What gears should I get ?
Hey guys check my page on my mods. Converting to a front of the engine belt setup so I can use a 3.0 pulley . What gears should I run, currently on stock gears
Old Sep 1, 2014 | 08:32 PM
zipper's Avatar
If you're looking for more performance, then you'll want the highest ratio possible. IIRC, 3.69's are pretty common. But if you want better fuel economy then go with a stock 4T65e-HD of 2.93:1. Otherwise, if you want a little bit of both, then go with a stock 3.29:1 found in the regular 4T65e. Those are the most common. If you change the gear ratio to a different one, you will obviously have to have the PCM retuned.
Old Sep 2, 2014 | 04:30 AM
turbo monte's Avatar
I would never do 3.69 gears in a street car. 2.93 gears turbo guys love and most sc builds I see use 3.29
I'm using a gmr 3.11 set but there very rare and pretty much no one even knows that ratio exists lol needless to say I love the 3.11 ratio on my turbo setup!
Old Sep 2, 2014 | 04:45 AM
l67ss's Avatar
runnin 3.29s on my l67
rgant_19
Sep 15, 2010 11:58 AM
buyrbware
Jun 29, 2009 08:44 AM
irocdu
May 15, 2009 03:20 PM
bwill314
Aug 21, 2008 07:56 AM
BeachBumMike
Oct 12, 2006 01:45 PM
